RST non starter
Old Dec 13, 2006 | 06:00 PM
V8ian's Avatar
V8ian
Default RST non starter
My son has just got a non running RST S1, it had a blown head gasket, and a new recon head fitted, as well as a new Turbo, I assume 8mm lift in a turbo shaft is excessive
When he got the car it just about ran, now, when it turns over first time if fires a couple of times then dies, and will not fire again unless you leave the car for a couple of hours, Im thinking metering unit, it was full of mayo, crack the feed to the front of the unit and there is plenty of pressure, but virtually nothing if you crack an injector pipe open, If I push the diaphram?? down when the ignition is switched on it makes no difference, no noises, nuffink any suggestions??
Ian
Old Dec 13, 2006 | 07:22 PM
SafeChav's Avatar
SafeChav
Remove one of the injectors, bridge the fuel pump relay, and push the flap. Fuel should spray from the injector when the flap is pressed and the pump is running........
Let me know the result!
Old Dec 13, 2006 | 10:52 PM
V8ian's Avatar
V8ian
cheers Ill do that tomorrow,
Ian
A.t.p
Oct 23, 2015 07:54 PM
cossie362
Oct 11, 2015 03:53 PM
Billy_RS
Sep 13, 2015 04:17 PM
marky_g
Sep 12, 2015 04:26 PM
