Dash Problem on Focus...., No speedo, rev counter etc etc
Old Nov 28, 2006 | 09:17 PM
Mike W's Avatar
Mike W
Default Dash Problem on Focus...., No speedo, rev counter etc etc
Posting this for my dad...
He has got a 03 plate Focus estate which as developed a strange problem...
Basically his speedo, rev counter, fuel gauge, temp gauge & mileage thingy have decided they dont want to work....Sometimes they work and sometimes they don't. For example he could start it up and they will be working then whilst going down the street they will stop working and vice versa.....
All the lights on the dash work, such as the little light that comes on if you put the handbrake on or the light that comes on when you open a door....but the gauges dont
Does anyone have any idea what the problem may be
Any help would be much appreciated...
Mike
Old Nov 29, 2006 | 02:12 PM
Mike W's Avatar
Mike W
Bump
Old Nov 29, 2006 | 09:58 PM
davecosworth's Avatar
davecosworth
IM BACK
have yo tested the gauges to see if they work turn on the ignition then off then hold the mileage reset button for 15 second then turn the igntion on whilst holding the button still then the gauges should go into test mode
Old Nov 30, 2006 | 08:24 PM
aj focus's Avatar
aj focus
not good news, ive got a 52plate st170 and have the same problem, took it to ford, and they said its not the sort of thing that can be repaired and you need a new instrument cluster, thatll be Ł478.92 for a new one, that price includes fitting though. hope your dad is sitting down when you tell him
Old Nov 30, 2006 | 09:30 PM
Mike W's Avatar
Mike W
davecosworth:
What is actually supposed to happen when doing that mate, we tried it and it came up and said Test but that was about it
aj focus:
I thought it may be a case of buying a new cluster My dad did ring Ford up and they said a new cluster would be Ł170....
Bleeding Fords
Cheers for the replies guys
Old Nov 30, 2006 | 10:19 PM
davecosworth
IM BACK
if you keep pressing it you can scan throught all the functions on the dash can also get up a eltronic speedo read charge rate compression ratio of engine there is alsort of info it is used for basic diagnosis. just try it when they are not working and working.
TPM961
Jan 15, 2018 10:50 AM
morg65
Escort MK 5 / MK 6
17
Sep 11, 2015 08:40 PM
imnoteasy
Sep 7, 2015 09:26 PM
CrOwSoN15
14
Sep 3, 2015 12:21 PM
