2 things need help with
Old Dec 15, 2006 | 06:15 PM
cosworth_wannabee's Avatar
cosworth_wannabee
Default 2 things need help with
hi all, does anyone know how a temp guage on a mk5 esccort is wired up, ive checked it all and its a fault in the wiring somewhere, so im just going to re wire it myself...any one know how??
and how do you check how much oil to put into the gearbox its a zetec 1.6 escort cheers ppl
Old Dec 16, 2006 | 01:05 PM
SafeChav's Avatar
SafeChav
Without sounding patronising.........How have you tested the wiring if you don't know how the circuit works.
The gearbox oil, im not 100% but its something like 5mm below the level of the filler plug. (assuming your car has a BC box) Check in a haynes manual would be your best option on that
Old Dec 17, 2006 | 10:51 AM
cosworth_wannabee
what ive done is changed the water temp dial to one tht i know works, its off a set of clocks out of my old mk5 escort. anyway, it does the same thing, it has power cos wen u turn ignition on/off it will move very slightly, but its as if ther is no signal. ive checked wher the sender connects to the plug and a parts shop said to bridge the wire to see if the guage moves at all thn, i did tht and still no change, so im thinking tht its along the loom somewhere where the prob is. any thoughts?? cheers for the gearbox tip
Old Dec 17, 2006 | 03:52 PM
SafeChav's Avatar
SafeChav
Right ok.
Well iof you bridge the plug then the gauge should go into the red section.
Continuity test the Brown Wire to earth.
Continuity test the other wire on the plug to the end at the clocks (unplug the clocks)
Old Dec 17, 2006 | 09:31 PM
cosworth_wannabee
sound m8
Old Dec 18, 2006 | 10:06 AM
Fudgey's Avatar
Fudgey
Baby Cheesus
for the gearbox, you need to fill it up on the front of the gearbox until the oil starts to dribble out, when it stops dribbling it fine.
the car MUST be on a level surface tho.
as for the wiring to the temp gauge, fook nows, after i fitted throttle bodies and aftermarket management to my mk6, it never worked lol
just shot straight up off the scale lol
Old Dec 18, 2006 | 05:38 PM
cosworth_wannabee
cheers m8 tht rli helps!!!
Mark_
40
Oct 2, 2015 04:40 PM
Fudgey
21
Sep 30, 2015 06:19 PM
rsguy
44
Sep 29, 2015 03:29 PM
