ford escort turbo diesel luke warm heater
hi everyone, i have a 1995 ford escort 1.8 turbo diesel, mk5 shape, the problem i have is the heater is barely warm so wont demist screen probably, i changed the thermostat, the temp guage hardly goes up, all the pipes feel hot. whats happening please help??????? happy new year!
blocked heater matrix on my escort tdi
thats what a friend said, what do i have to do to solve the problem or should i buy a new one, how easy are to remove/fit???
Re: blocked heater matrix on my escort tdi
centre console out back gearbox mount off to get to the water pipes. centre vents out undo the dash board so you can pull it off a bit.but leave dash clocks in etc. and there is a steel bracket plate,behind the dash 4 bolts undo that,then you can pull the heaterbox down. two nuts hold the heater box in,pull it down, just a little to get the heater matrix out,it slides out. its not easy,shit job to do.
Your tellin me you have to drop the rear engine mount out to do a heater matrix..........
Never!
The mount isn't even that close to the matrix, and the rear mount is a right cunt to get off! fuck that!
Never!
try reverse flushing with a hosepipe and watch the sh-t come out!!! chances are its just a build up of crap, reverse flushing in general removes it,
DONT DO IT ON THE DRIVE!!! IT GETS INTO THE TARMAC/BLOCKS AND IS A BITCH TO GET OUT!!!!!!!!
blocked heater matrix on my escort tdi?
thanks for the advice everyone, going to put some coolent flush in today, then this afternoon will back flush it, since changing the thermostat there is a little bit of heat but not a lot. so hopefully should get some results, now descovered that i have a rear wheel bearing gone, never done one of these how easy will it be???
if its got a mtx75 gearbox in then yes you have to take the back mount off as there is no room at all to get the matrix pipes off,also the turbo and intercooler is at the rear so no room to get your hands in, if you have done one you will know .
matman
09-09-2015 05:45 PM
