ERST s2 water temp
Old Nov 27, 2006 | 08:39 AM
nick_rst's Avatar
nick_rst
Default ERST s2 water temp
Hi!
While driving my erst's water temp gauge goes up nearly to the red area (but not in!), then the cooler fan starts and the temp comes back to normal.Is it normal, or there's a problem in my coolant circuit?
Thanks!
Old Nov 27, 2006 | 09:55 AM
Alvyn's Avatar
Alvyn
just as a pre caution change the temp sender unit (in the cylinder head) and cooling fan switch also on the head!
ps as it's NOT over heating ie the engine boiling over it COULD be that the needle on the gauge IS reading wrong as in too high!
Old Nov 27, 2006 | 10:06 AM
nick_rst's Avatar
nick_rst
Thanks!
Old Nov 29, 2006 | 06:58 AM
Maki's Avatar
Maki
One stupid sugestion. Check if the thermostat is in the right direction in
Mark RS
Oct 12, 2015 06:01 AM
Mc5506
Oct 5, 2015 09:57 PM
DAZZER
Sep 30, 2015 08:43 PM
