BENO'S ZETEC TURB PROJECT
HI JUST WONDERING IM USING OFAB WHAT AP SENSORS CAN USE AND IF I USE A COSSIE ONE WILL I NEED TO MAP IT OR WILL IT RUN OK
![007](https://passionford.com/forum/images/smilies/bond.gif)
Map sensors - OFAB uses a Marelli 2 bar standard. You can run a cossie 3 bar one but you will need a chip, and could be a pointless venture dependent on how much boost you are going to run.
hi im new to turbos so i dont know much i build mk3 fiesta zetec turbo is it possible to use the standard seirra cossy map sensor with out chippin it
what about the head i know it looks rough i gonna refurb it just that i on a serous buget with havin 3 kids
A standard cossie one may well work, if thats a 2 bar marelli. Check the part number on it.
Yer thats what i meant, rusty cams and stuff
You wouldn't wana just fit it as it is and hope for the best, if your refurbing it should be all good
![Surprised](https://passionford.com/forum/images/smilies/shocked.gif)
![Smokin](https://passionford.com/forum/images/smilies/icon_smokin.gif)
the engine will be refurbd cleand ad painted but the 1800 is only the prototype when i can afford the forged pistons ill be building a 2ltr
![Much is the "Yo"](https://passionford.com/forum/images/smilies/ok16.gif)
mk3ste
17-10-2021 10:09 AM
07-10-2015 12:56 PM
SMILER258
28-09-2015 09:04 AM
