hand brake problem xr4x4 help needed mot due
Old Apr 11, 2011 | 08:33 PM
gazdon's Avatar
gazdon
wheeler dealer
Default hand brake problem xr4x4 help needed mot due
hi all i have changed the rear pads on my xr4x4 (rear discs) and have fitted a new hand brake cable but cannot get the hand brake to work properly i can adjust the cable all the way up on the adjuster and the hand brake still travels to high. the levers on the calipers move ok and i can wind the piston in and out ok i have so bleed them what eles can i do mot is due soon forgot to mension the hand brake works to some degree as the bakend of the car lowers when trying to pull away but still moves can anyone help.
Old Apr 11, 2011 | 08:48 PM
dannyrscos's Avatar
dannyrscos
are the calipers working properly wip your pads out again screw the piston back in get some one to pull hand brake so you can actually see them working out again if there both working be sure to get the cuts in the pistons level with the pads locating peg on the back of the pads
Old Apr 11, 2011 | 09:08 PM
gazdon's Avatar
gazdon
wheeler dealer
hi what do you mean by the pads locating peg on the back of the pads regards gaz
Old Apr 11, 2011 | 09:41 PM
dannyrscos's Avatar
dannyrscos
on my cossies the rear pads have little lugs on the back which i presume locate in the slots that u use to screw the pistons back in with but just wondering weather you been given the right cable wonder if its an estate or a granny one mate
Johnsie
Ford Focus ST
Sep 8, 2015 02:39 PM
Mad_Mat
Alloy wheels and ICE for sale
Aug 28, 2015 10:03 PM
track.focus'd
Aug 12, 2015 05:53 PM
col93saphcos
Aug 7, 2015 03:21 PM
Graceland
Jul 31, 2015 10:34 AM
