a quick sierra cosworth id question
Old May 12, 2011 | 06:13 PM
cossie j's Avatar
cossie j
Default a quick sierra cosworth id question
im in the process of buying a 3 door cosworth and was just wondering if there is a way of checking if its a genuine sierra cosworth by the floor number the log book states cosworth on it and i'v done a hpi check i just wont too be 100% befor handing over my cash any help will be much appreciated cheers j
Old May 12, 2011 | 06:21 PM
martysmartie's Avatar
martysmartie
Pretty good indication yes the VIN number should tally with the log book, look for any signs of welding around it or if any of the numbers look tampered with in which case it's a ringer.
Also the last 7 characters tally with the engine number, although this could quite understandably changed!
Martin
Old May 12, 2011 | 06:23 PM
PAUL S's Avatar
PAUL S
tap in the vin on here and it will decode the sequence confirming the build data, it should be a genk built rhd sierra 3dr assembled between july and december 1986
http://www.btinternet.com/~madmole/vindecoder.html
Old May 12, 2011 | 06:36 PM
cossie j's Avatar
cossie j
thanks for the replys this is what i got back does it sound right for a cosworth
Your VIN Decoded
The VIN code WFOEXXGBBE breaks down as
Manufacturer Identifier: Ford Werke A.G. (Germany)
Body type: 3 Door Hatchback
Line: Ford Germany (Own Assembly)
Assembly Plant: Genk (Belgium)
Model: Mondeo/Cougar/Sierra/Cortina/Taunus
Year: 1986 (some codes are used for more than one year)
Month: September
Production Sequence: 41486
Old May 12, 2011 | 06:52 PM
nellyscossy's Avatar
nellyscossy
sounds like a cossy to me the wfoexxbbe is deffo the begining of a three door cosworth vin number
Old May 12, 2011 | 06:59 PM
cossie j's Avatar
cossie j
thats what i like too hear
charliecosworth
Aug 19, 2015 02:00 PM
cossie4x4
Aug 14, 2015 06:29 PM
155lee
Aug 14, 2015 11:21 AM
dal3door
Aug 13, 2015 06:55 AM
martynhomer01
16
Aug 4, 2015 09:55 PM
