Focus motor / regulator
Old Apr 6, 2011 | 03:32 PM
dickybow's Avatar
dickybow
Default Focus motor / regulator
Hi
My drivers windows does not ok, motor gets its 12v feed both ways according to the volt meter, so obviously its the motor...
A lot of topics on this suggest removing the 4 screws to take the casing off. I did this and even using brute force the casing wouldnt slide off.
Instead the motor and the spindle (?) came off which the motor is clearly knackered.
Can I replace just the motor or will I need to swap the gears / cogs etc ??
Thanks
JK12
33
Apr 26, 2021 12:09 PM
Dubs44
Sep 19, 2015 06:31 AM
marky_g
Sep 12, 2015 04:26 PM
dojj
Sep 8, 2015 08:31 AM
natehall
Ford Focus (All Models)
Sep 8, 2015 05:13 AM
