cam timing help?
Old Apr 10, 2011 | 07:13 PM
m4tt274's Avatar
m4tt274
Default cam timing help?
i have a triumph t140V and i am rebuilding it.
problem is, i know how to time one standard but i have a race cam.
how would i go about timing it? or would i?
how you time it standard
std cam vs new cam
Old Apr 10, 2011 | 07:30 PM
Chaz888's Avatar
Chaz888
wots the main difference lift ,timing ,duration ? looks like the rear lobe set times different ?
Old Apr 10, 2011 | 08:14 PM
JonathanJ's Avatar
JonathanJ
I have just found a couple of pages with information about the cams , trouble is they seem to be very cam dependent as they are on cars , you really need to know exactly what race cam you have , is there any numbers on it , then you might find to check it you need 2 dti gauges and check to specification .
http://www.johnsoncams.com/jc_t_cams.html
http://www.postdiluvian.org/~mason/moto/cam-timing.html
Just 2 pages to look at , will help if we can
Old Apr 10, 2011 | 08:33 PM
m4tt274's Avatar
m4tt274
superstars!
i will now read through that all thankyou!
RUBY123
Oct 22, 2023 12:04 PM
Danielbetty
Oct 3, 2015 06:01 PM
martsmotor
Ford Focus Range
Aug 27, 2015 08:08 PM
JoeyBoyden
20
Aug 22, 2015 03:23 PM
taylora1409
Aug 12, 2015 12:06 PM
