Mondeo tdci 2002 - Starting Problem
hi i have a mondeo tdci 2002 its just started having problems with starting, i wont turn over , when i turn the key its makes a sort of whining noise from engine?
a guy looked at it and said put it in third and he moved it back a bit and then it started??? he said it could be the dual mass fly wheel which is a major job
!! but could also be starter motor?? can anyone please advise
thanks
![](http://images.ibsrv.net/ibsrv/res/src:passionford.com/get/forum/images/smilies/icon_sad.gif)
thanks
soudns like starter motor not engaging correctly.
dual mass flywheel wont stop the car from starting, it will make a horrendous noise when cranking.
if he put it in gear and rocked it this would have released the starter motor if the pinion was stuck.
start cheaper and fit a new starter motor.
hi, defo the starter, the same thing happened to my 2002 tdci when i bought it, got it recovered by the garage i got it from and they told me the starter had gone, they supplied and replaced under warrenty.
