Anyone knows what this means?
Old Apr 26, 2011 | 12:48 PM
azzkill's Avatar
azzkill
Default Anyone knows what this means?
P0353 Ignition Coil C Primary/Secondary Circuit Malfunction
Does it mean i have a faulty coil pack?
Old Apr 26, 2011 | 12:58 PM
JonathanJ's Avatar
JonathanJ
It can be either coil , wiring or the ecu raising this fault code , check wiring first unless you have a coil at hand
Old Apr 26, 2011 | 01:05 PM
azzkill's Avatar
azzkill
I do have an coil at hand so think I will test to swap. The other day the car started running poor. And I checked for fault codes and it showed missfire on cyllinder 6. So I swapped the spark plugs today. And now it runs even worse and showes the fault code about the coil. just pushed over all the cables now and started again, and it showes one more fault code. wich is P0352 Ignition Coil B Primary/Secondary Circuit Malfunction.
Could this have anything to do with my resent installment of bluefin chip?
Old Apr 26, 2011 | 03:34 PM
JonathanJ's Avatar
JonathanJ
it could have but seeing you have swapped plugs and the fault has either moved or got worse , might either be a plug or the coil wiring at fault
Old Apr 26, 2011 | 04:29 PM
azzkill's Avatar
azzkill
just swapped the coil now and it still is shit, with the two error codes. I know this coil is working. Going to check the plug leads are set correct, 99% sure they are but never know. Last thing I know I can do then is to swap the plug leads.
Old Apr 26, 2011 | 05:29 PM
azzkill's Avatar
azzkill
Default Problem solved
Sorter The problem. All The leads were attached corect but probably not good enough. Pushed and twisted on all og them and now it runs perfect. My old sparkplugs was really bad. Some of them had less than half the gap they should have and had started melting.
But now it's all good thanks jonathanJ for The help.
Mile30
69
May 13, 2017 08:44 PM
deathrider666
Sep 28, 2015 06:12 PM
Andypandy260
Sep 23, 2015 10:28 PM
morg65
Escort MK 5 / MK 6
Sep 23, 2015 08:57 PM
oilman
Trader Parts for Sale.
Sep 23, 2015 07:32 PM
