help on brakes
Old Apr 25, 2011 | 10:31 PM
rs2000-trev's Avatar
rs2000-trev
Default help on brakes
i have taken my engine out of the ka and im putting a bike engine in the rear but there is a vac hose that went from the brake master cylinder to the top of the inlet manifold and i think im going to need this for my brakes to work dose anyone have any clue as to what i can do here.
Old Apr 26, 2011 | 07:12 AM
If you want to keep the servo assitance, you can buy a vacuum pump that is electrical, failing that other options are if the brakes are too hard fit a different master cylinder, I'd be mazed if they were too hard even without the servo assistance.
I'm assuming the bike engine has itb's ?, you could always tap into one tb for a vac signal but likely to be very little.
muzzman1
Sep 30, 2015 08:59 PM
Sp3no
Sep 27, 2015 07:23 PM
