help needed engine stuttering/jerking when accelerating
Old May 4, 2011 | 08:32 PM
matty_'s Avatar
matty_
Default help needed engine stuttering/jerking when accelerating
hi, first post so some simple advice would be appreciated,
right i have a 1998 ford fiesta 1.25 zetec,
engine was running fine but then the car started stuttering/jerking and i noticed that i was low on petrol so just thought it was this, but i was wrong.
now the car stutters/jerks while accelerating hard, mainly in 2nd.3rd gear but does it in all,
i checked all spark plugs and HT leads they seam fine,
topped up with fuel,
replaced TPS
cleaned throttle body with carb cleaner, but the engine still stutters
could it be a dirty/clogged fuel filter? or anything else.
BTW the car idles ok-ish it idles about 1100, but drops and rises a little but nothing major, thanks guy
matt
Old May 5, 2011 | 07:13 AM
oldford's Avatar
oldford
High idle is an indication of an air leak. Check for split/cracked hoses.
Is the exhaust completely leak free? Check around the oxygen sensor.
Old May 5, 2011 | 10:01 AM
lockhead's Avatar
lockhead
Could also try to disconnect your MAF, this will make the ECU use a pre-stored value instead of that from MAF. If that dosn't help, stop guessing and get a faultcode read out done. Might be a problem with the harness to the TPS aswell, Autodata had some notes about that being a standard issue...
Good luck!
Old May 5, 2011 | 10:05 AM
matty_'s Avatar
matty_
ive already disconnected the MAF, this did reduce the jerking but it was still happening, thanks for the helps guys
Old May 5, 2011 | 10:09 AM
matty_'s Avatar
matty_
forgot to mention, NO ENGINE MANAGEMENT LIGHT HAS COME ON
matt
Old May 5, 2011 | 10:40 PM
Alvyn's Avatar
Alvyn
try a new coil!
Old May 6, 2011 | 03:17 PM
matty_'s Avatar
matty_
Originally Posted by Alvyn
try a new coil!
yeap, i have 2 near new coils and leads on their way as i know the fiestas have this problem, so hopefully one of them will work.
cheers guys
matt
Johnsie
Ford Focus ST
Sep 8, 2015 02:39 PM
Bailes1992
Aug 16, 2015 07:14 PM
track.focus'd
Aug 12, 2015 05:53 PM
col93saphcos
Aug 7, 2015 03:21 PM
fatboy billy
Aug 3, 2015 08:34 AM
