which caliper is this :S
Old Apr 25, 2011 | 10:58 AM
Wrig's Avatar
Wrig
Default which caliper is this :S
hi, went to change my pads bought them from euro parts for abs mk5 fiesta, and they were to big went back and the pads i needed were for none abs (even though mines abs)
went to put them on a piston on caliper was seized, ive bought to calipers now which turned out to be the wrong size (to big) and the places seems to think that the brakes were changed to diffrent ones at some point.
so which caliper is this? its got the number 847 on it, its smaller than the ones ive bought, has a 44mm piston. goes on a solid disc (ive been told these should be vented) heres the brake pads that fit it and a pic of the caliper its self:
http://www.eurocarparts.com/search/101590041/p/home
Old Apr 25, 2011 | 11:54 AM
dojj's Avatar
dojj
Resident Wrestling Legend
there are only really 3 calipers it can be
the standard 240mm calipers
the larger rsturbo/sierra 260mm calipers
the biggest escos/4x4 sierra cas/granada cos/mondeo V6 278mm calipers
depending on which rims you've got on i'd be going with the 260mm calipers
Old Apr 25, 2011 | 12:03 PM
Wrig's Avatar
Wrig
where do you mesure it to get the 240/260/278mm?
heres a picture of what i bought that was the wrong one (got off a mk4 fiesta and seems to be the most common) this one is bigger than the one i need
Old Apr 25, 2011 | 12:07 PM
Jimmyc's Avatar
Jimmyc
Those sizes Dojj quoted are for the brake disc diameter bud.
Old Apr 25, 2011 | 12:11 PM
Wrig's Avatar
Wrig
think i may of found one is this it
BCA1898 - 6380
http://www.brakepartssuperstore.org....-uk/d6380.html
jimmyc- that makes sense opps
Old Apr 25, 2011 | 02:51 PM
Measure your disc diameter, it's likely to be 240mm or 258/260mm, the pads you need are for a ATE caliper, the abs cars were indeed all vented disc, looks like someone been playing mix and match at some point.
Old Apr 25, 2011 | 04:32 PM
Wrig's Avatar
Wrig
240mm it is, and it does looklike someones been mixing n matching
Nov 1, 2015 06:53 PM
muzzman1
Sep 30, 2015 08:59 PM
Sp3no
Sep 27, 2015 07:23 PM
DPDISXR4Ti
Ford Fiesta
Sep 21, 2015 03:51 PM
cossirob
Sep 3, 2015 09:17 PM
