OFAC v OFAB
Old Apr 11, 2011 | 11:11 AM
Carson's Avatar
Carson
Default OFAC v OFAB
Im currently collecting the parts to convert my Mk5 fiesta Engine for the 1.6 FRST.
Im now looking for the ECU and loom but im abit of a novice with the old skool ford stuff, so....
What is the difference between the OFAB and OFAC ECU's and wiring looms??
Old Apr 12, 2011 | 10:23 PM
MO' BENT RIMS's Avatar
MO' BENT RIMS
all i know is that the ofab is better
Old Apr 13, 2011 | 07:22 AM
JonathanJ's Avatar
JonathanJ
I would say that at normal boost pressures they are very similar in their output capabilities , where OFAB is better is when boost pressures get higher i.e. above 1.5 Bar as the std OFAC map sensor can only measure to this as a limit of boost and there is not an uprated item available , a std OFAB item can measure up to 1 Bar boost but can be swapped for either a 1.5 Bar boost (2.5 Bar total measure ) or a 2.0 Bar boost ( known as a 3 Bar map sensor as this is what it measures including vacuum ) .
I have just swapped my OFAC for OFAB not for performance but so I can get bits easier , the only issue with OFAB is the suppressor that ford decided to fit between map sensor and ecu , but a lot of people do not run these and do not seem to have any issues .
It is really down to personal choice and what you can get hold of .
Old Apr 13, 2011 | 07:44 AM
1.9 xr2 on 40's's Avatar
1.9 xr2 on 40's
st170 breaking
pm me for ofab gear
its live mapped too
Dahl88
Aug 22, 2015 08:16 PM
black_FRST
21
Apr 8, 2005 10:35 PM
Dec 25, 2004 09:29 PM
1.9 xr2 on 40's
Sep 17, 2004 05:13 PM
rickfiestaRST
Fiesta RS1800/RS Turbo
Jan 28, 2004 11:58 AM
