ecu help........
Old Apr 14, 2011 | 05:33 PM
turblower's Avatar
turblower
Default ecu help........
can u replace a L1 ecu for a diffrent type L6,L8 etc with out causing damage?
Old Apr 14, 2011 | 05:38 PM
L1 can directly be replaced with a L6, BUT you will have to use a L6 chip also in the L6, ie the chip won't swap.
The L8 can be used, by using a 4wd tps and swapping the outer two wires on the tps around with each other, again a L8 chip will be needed for this.
Old Apr 14, 2011 | 05:50 PM
turblower's Avatar
turblower
cheers tabetha,i have blown a l1 ecu an needed replaced,ill start the hunt for a L6..
Old Apr 15, 2011 | 08:04 PM
Just don't pay silly money, you can get a V4 ecu for £450 fitted and mapped brand new with new loom, so do some sums first, a mapped engine is massively better than a regular chip swap, and well worth the extra imo.
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
griffo69
Oct 4, 2015 11:58 AM
R4N SS
Ford XR Parts For Sale
Sep 15, 2015 03:38 PM
DixieTheKid
Sep 14, 2015 09:04 PM
Tank Mike
Sep 14, 2015 03:56 PM
