Cosworth Throttle Cable Adjustment ?
Old Apr 30, 2011 | 08:36 PM
Hoogi's Avatar
Hoogi
Default Cosworth Throttle Cable Adjustment ?
Any tips on adjusting a Cosworth Throttle Cable ?
Thought it should be straight forward but I seem to either have a "baggy" spring at the Throttle Body or have "run-out" of all of the adjustment ?
Is some of the slack taken up once the other end is attached to the Pedal ?
The spanner in the works is it's a Cossie Engine in a MKII Escort
Old Apr 30, 2011 | 09:10 PM
The spring does keep some of it's "bagginess" on cossies even when adjusted up.
Old May 1, 2011 | 05:23 PM
Hoogi's Avatar
Hoogi
Thanks again Tabetha
jessie_rs
11
Jun 3, 2019 04:57 PM
Graham S1
Technical essay Archives
Aug 24, 2015 03:58 PM
Aug 20, 2015 09:21 PM
Aug 14, 2015 07:29 AM
M K
Aug 12, 2015 06:57 PM
