Focus 1.8tdci, non start
Old May 2, 2011 | 04:34 PM
davetdi's Avatar
davetdi
Default Focus 1.8tdci, non start
Hi all,
Im a newbie here as my daughter has just got a focus 2002 1.8tdci and its playing up.
She was parking outside her house when it just cut out. She tried restarting it but it fires up for a second then dies.
I have held the trip counter and it displays the dtc code 9318 which is low batt Volts , so I stuck a decent battery on there and the problem persists.
I changed the cam sensor, no luck.
other info which may be relevant:
She does have a habit of driving to the range guide and regualrly runs it down in the tank to the bottom. I am saying this as it does feel like a fuel issue to me.
When the car konked out there were no warning lights on at all, and none came on.
About a month ago it kept stalling and had no throttle response, so I changed the throttle pedal assembly which cured it.
When it was running the revs used to die away after 3200 rpm rather than around 4400.
Any ideas as to where to go next and what to check for before I have to give it to a garage.
Anyway many thanks for your help in advance
Old May 2, 2011 | 05:16 PM
WillyWoW's Avatar
WillyWoW
Do you know when the fuel filter was last done on it?
Old May 2, 2011 | 06:38 PM
davetdi's Avatar
davetdi
Hi
No I don't know, how likely is this to be the fault?
Old May 2, 2011 | 06:42 PM
davetdi's Avatar
davetdi
And is there a special way to bleed up after fitting a filter or just fill it up first?
Old May 2, 2011 | 06:57 PM
syko2005's Avatar
syko2005
burning oil
My focus tdci had a service earlier in the year and after the fuel filter change it ran like shit for about 2 week. It started on the key after the service but seemed to take forever to get rid of air out the system. Although they are supposed to be self bleeding
Old May 5, 2011 | 10:30 PM
davetdi's Avatar
davetdi
hi all
update, downloaded some error codes from the system on it tonight
they are p1631
and p0191
any ideas what these are and how to fix?
salsheikh
Ford Focus ST Parts for Sale
Oct 6, 2019 07:56 PM
Fordmad!
Sep 26, 2015 05:24 PM
salsheikh
Ford Focus RS Parts for Sale.
Aug 20, 2015 12:22 PM
saph in dorset
Aug 14, 2015 10:10 AM
track.focus'd
Aug 12, 2015 05:53 PM
