coverting wings to bolt.
Old Apr 27, 2011 | 09:42 PM
chris m1's Avatar
chris m1
Default coverting wings to bolt.
how hard is it convert the front wings of a mk4 escort to bolt on?. Is it a case of drill out the welds and redo with 8mm bolts.. how do you sort out the slam panel join?..
Are the spot 8mm or 10mm?
all idea welcome
Old Apr 27, 2011 | 09:55 PM
mk1turboestate's Avatar
mk1turboestate
i did this but i spot welded a 3mm plate under the wing rail and drilled and tapped bolts into it, the slam panel you can use self tapping bolts like the ones used to secure flat roof trim, can be bought from b&Q, you also need to bolt it on to the a A post
Old Apr 27, 2011 | 09:57 PM
chris m1's Avatar
chris m1
Hadn't thought of that..Im right in saying its just 4/5 spots on the top and then down on the cill?
Old Apr 27, 2011 | 10:06 PM
mk1turboestate
to be honest it depends who put the wing on, there could be alot of welds, just be carefull and use a spotweld removal drill bit so you dont damage the wing rail, the proble is the a post as its normally mig welded on
Old Apr 27, 2011 | 10:15 PM
chris m1's Avatar
chris m1
there pattern wings as there's no ford markings and they sound cheap when you tap them..but ill have a look.. how does it fit on the cill
Old Apr 28, 2011 | 07:59 PM
afaik it's a MOT fail, where welded by any means originally it has to be the same when replaced, so might pay to check with your mot man first ?
gcfcos
59
Oct 6, 2015 05:04 PM
stephenb4506
33
Oct 2, 2015 06:25 PM
Iain Mac
Sep 30, 2015 09:39 PM
