Water Temp Housing......
Old Apr 11, 2011 | 07:48 PM
Hoogi's Avatar
Hoogi
Default Water Temp Housing......
I've just removed the small Alloy Housing that sits at the back right hand side of the Cosworth Head.
The bit that holds the Water Temp Sensor, and that also has the push on fitting.
A bit suprised to find no gasket..........is this how it should be - just a face to face fit
Many thanks
Old Apr 12, 2011 | 08:29 PM
NO, should have a gasket, cometic do a re-useable one as well, about £3-£4.
Old Apr 12, 2011 | 08:42 PM
Hoogi's Avatar
Hoogi
Cheers Tabetha.........
Nov 1, 2015 06:53 PM
Mark RS
Oct 12, 2015 06:01 AM
DAZZER
Sep 30, 2015 08:43 PM
