Cosworth oil pressure ?
Did once have a problem on a van splitting filters because the relief valve had jammed. I'd be suprised on a cossie though, it's got piston spray jets like underwater gas pipes What pressure have you got?
Yes you can, it robs bhp to start with, causes the oil temperatures to rocket, as it is squeezed more for pressure, which causes it to thin out a lot more, leaks from gaskets become more likely also, oil pumps have been know to explode, but that's mostly the genuine cosworth SHITE they have produced lately!!
Do you have a problem with pressure too high, and how high is high ?
Sorry a bit off subject but like to learn as much as poss
My escos when first started from cold goes to 5bar, once warm drops to around 3bar,,not sure if thats good or bad,,its always been like that though,
cheers
scott
cheers
scott
I get about the same and have a HP pump, the referred to below was Cosworth that had a batch of exploding pumps that were recalled IIRC.
I don't think the pump is everything rather it's down to an engine, I.E the pump creates flow, the engine keeps the pressure, hence why a knackered engine has lower oil pressure but equally could be caused by a bad pump, but say if you put a HP pump on a knackered engine I doubt you will get the pressure you would on an otherwise good engine, thats my thinking anyway.
Martin
Martin
The idle pressure when hot isn't so/as important as the pressure by about 2000rpm when load can be applied to the engine, no load at idle, with oil temp around 80C the above are fine, obviously will go down as gets warmer, what oil are you using for those pressures ?
Oddly the ford handbook lists a 30W as best for the yb, but can be seriously harmful, I wouldn't use anything less than a 50 weight personally.
hi just to let you no that on my engine from cold it about 60 62psi and when nomal temp its around 25 30 psi i but if iv been killing it down the lanes for a bit its something like 18psi on idle...
Is not possible to buy titan race pro S 10W/50 in our contry ... I dont know why. Google says nothing...
Only 10W/50 fuchs silkolene pro 4 plus 10w-50 but this is for racing motocycles..not for cars
I found only
Q8 Formula F1 10W-50 (4 l)
( API SM/CD, ACEA A3, BMW Special Oil, MB 229.1)
I found only
oilman
Trader Parts for Sale.
30-08-2015 08:37 AM
mrmann
20-08-2015 11:24 PM
