2wd gearbox oil
Old Apr 22, 2011 | 10:59 AM
chrisa3's Avatar
chrisa3
Default 2wd gearbox oil
Just refitted my saff 2wd gearbox yesterday. I filled it till it was running out the filler hole. But has only taken 2litres of fluid. Everywhere I looked says 2.5 litres. Do you have to add more after running the engine, or is 2 litres about right??
Old Apr 22, 2011 | 06:44 PM
Was your box apart and emptied of oil ?, if it is running out of the filler hole then it's got enough, so must already have had some in, I filled mine about 3 weeks ago from having been completely stripped, and it took nearer 2.7 litres.
Old Apr 22, 2011 | 06:49 PM
chrisa3's Avatar
chrisa3
Its been out the car and down to the gear shop. Its had the bearings reshimmed but thats it. Definately running out the filler hole, so musnt have been completely empty.
Old Apr 23, 2011 | 06:39 PM
Alvyn's Avatar
Alvyn
as long as your checking with car on level ground or a ramp and the oil's coming out the bung hole then it's fine!
Adam Graham
Sep 6, 2015 06:04 AM
jc1989rs
Sep 5, 2015 08:09 PM
gingeRS
Sep 4, 2015 06:29 PM
oilman
Trader Parts for Sale.
Sep 4, 2015 09:34 AM
hopper350
Sep 4, 2015 12:53 AM
