6 degree beam info
Old Apr 25, 2011 | 06:17 PM
anglia105e hinson's Avatar
anglia105e hinson
Default 6 degree beam info
after looking into the 6 degree rear beams that danny B /Ahmed b make. am i right in saying that looking at the pictures below from another thread.
the inner arm points have been moved further towards the front of the car thus making the angle that the arms are pivoted through to 6 DEGREES
because these are moved forward, there is alot less camber change as the arms move up and down through there arc. and with the adjustable rose joint this can be even less
to keep the wheel flat at all times to the road, a 0 DEGREE rear beam would be better suited. ie, for drag racing. so this means that moving that point even further forward would create this. (true trailing arm ) instead of a semi-trailing arm
but can a true trailing arm be as competitive through the corners? as it doesnt allow the toe or camber change as the car rolls through corners.
the reason i am asking this is because i'm going to make one that will convert it to true trailing arm as i want the best grip for 1/4 mile. but obviously it will still be a road car. i reckon i will see gains in grip over these setups. will there be any disadvantages for a fast road car
i know that danny b/ahmed rear beams are a very good bit kit and i can appreciate the time and effort that has gone into these setups being a welder/fabricator myself so am in no way knocking there setups.
i would like to hear all positive and negative comments for my proposed idea
cheers
Luke Hinson
Originally Posted by Daveysaff
Ahmeds Beam:
I *think* this one of Danny B's:
http://cosworth.hu/?menu=galeria&page_id=2
Useful stuff on there, also, have a look at B9KOS's resto thread. He's got one of Adrenalines tubular jobbies
Old Apr 27, 2011 | 09:00 AM
anglia105e hinson
Anybody got any Thoughts on this must a few suspension gurus here
Cheers luke
XR4
Ford XR Range
Oct 1, 2015 12:46 PM
Mc5506
Sep 29, 2015 09:06 AM
DavidK
Sep 27, 2015 02:55 PM
