turbo damper removal
Old Jul 3, 2010 | 11:14 AM
brooksy898's Avatar
brooksy898
Question turbo damper removal
hi, im trying to remove my turbo damper of my turbo but the bolts wont come out of the bloody thing any ideas how to get the buggers out.
Old Jul 3, 2010 | 01:54 PM
If you are refffering to the bolt that goes through the spring, and is locked at the end with a 10mm nut, then just use some thin nose pliers in between spring coils to hold bolt shaft.
Old Jul 3, 2010 | 03:06 PM
brooksy898's Avatar
brooksy898
im on about the turbo damper bracket hanger thats attached the the turbo. the bolts that attach the hanger are stuck in. what the best way of getting them out. ive tryed heating them up but got nothing out of it. is there any other way
Old Jul 3, 2010 | 05:06 PM
Plenty of heat from a proper blowtorch, not a diy type, need heating till cherry red/orange hot.
Matt Baxter
Sep 16, 2015 08:30 PM
Aug 29, 2015 08:16 PM
A.t.p
Aug 15, 2015 11:37 AM
kevin36
Aug 14, 2015 08:36 AM
