cosworth saver shim
Old Jul 2, 2010 | 04:50 PM
brooksy898's Avatar
brooksy898
Question cosworth saver shim
I have recently had my cylinder head on my 2wd sapph skimmed and it measure's to be 138.50. I now its under the reccomended limit, But i heard about a saver shim for the cosworth that i can get hold of. what im wanting to know is are they a good under all that pressure and do they work properly with no hassle. Does anyone reccomend them or use them and has had any problems. cheers
Old Jul 2, 2010 | 07:36 PM
The "problem" is that the exhaust port seats fall out when running lots of boost big bhp on heads that have been skimmed too much.
Personally I wouldn't worry at your head thickness unless you're going for 500+ and tracking it etc ?
The seats can be stitched in if necessary.
Old Jul 2, 2010 | 11:43 PM
brooksy898's Avatar
brooksy898
but what im asking is is it worth getting a saver shim to put the compression right and to be on the save side from any piston to valve contact.
Old Jul 3, 2010 | 01:59 PM
I've never know it be needed yet tbh from a head skim, don't worry about CR, the amount really is insignificant in relation to the sept volume of the piston, head/volume, won't cause a problem.
Ford Focus RS Parts for Sale.
Mar 9, 2016 01:03 PM
Billy_RS
Sep 13, 2015 04:17 PM
28
Sep 8, 2015 07:10 PM
Adam Graham
Sep 6, 2015 06:04 AM
wheelwizardrefurbs
Sep 5, 2015 10:52 AM
