cossie idle problem
Old Jul 21, 2010 | 08:37 PM
jonnyc's Avatar
jonnyc
Default cossie idle problem
Anybody know how to sort out issues with idle speed as my car is reving up to 6000 on start up. 1992 saph cossie.
Old Jul 21, 2010 | 09:07 PM
Revheadcosworth's Avatar
Revheadcosworth
have you tried cleaning out or replacing idle control valve?
Old Jul 21, 2010 | 09:23 PM
studabear's Avatar
studabear
check throttles not sticking
check for air leaks
can you get it on a monitor/diagnostic equip?
Old Jul 21, 2010 | 10:31 PM
jonnyc's Avatar
jonnyc
Throttle not sticking. no air leaks sprayed some stuff and it did nothing. ISCV Is clean and the iner part moves freely, Disconected the ISCV and this brought revs down to 2500 which got me home. Tried reconnecting and it shot back up to red line. Dissconected TPS and this made no difference also. Car was starting abit iffy before this happened last night but only for 2 seconds and then it calmed down to around 1100rpm but know it is riddiculous.
Old Jul 22, 2010 | 05:02 AM
rubinsbin's Avatar
rubinsbin
by disconecting then reconecting highlights a iscv problem-no??
Old Jul 22, 2010 | 08:03 AM
martysmartie's Avatar
martysmartie
No, the fact the revs are changing when connected and disconnected shows the valve is being TOLD to do so.
Even when D/C though the revs are still at 2K+ so I would say the valve has got stuck a little, I would take out and clean and re lube using a light lubricant such as WD40 or brake fluid etc, make sure it is not open slightly.
As to why it's doing it I would check the ISCV has not got earthed, chaffed wiring etc.
Martin
15
Oct 7, 2015 03:43 PM
RSmark84
Sep 13, 2015 01:29 PM
Marino
Sep 12, 2015 11:10 AM
natehall
Ford Focus (All Models)
Sep 8, 2015 05:13 AM
