zetec engine conversion help!!!
Old Jul 17, 2010 | 04:08 PM
johnnyboy1987's Avatar
johnnyboy1987
Default zetec engine conversion help!!!
hello everyone at passionford, i am in need of help as i cant fix my bloody car!!!
im currently installing a 2.0 zetec (silvertop) into a mk4 escort, running a 32/36 dgv twin choke carb, everything else is completely standard.
at the moment all i seem to be getting is like an entire engine misfire,
rev it up its the same,and introduce more fuel, its the same
ive pulled off all the leads to see if its one cylinder but no single one makes any noticeable difference.
ive changed the leads, changed the plugs, changed the coil pack
ive double checked the timing
ive checked my intake manifold for air leaks
checked the crank shaft sensor/plug are all working correctly fitted.
doubled up the earth and live for the esc ignition module
ive let it get warm incase it could be followers sticky or anything
the only thing i havent done is a compression test but i drove the engine in the donor car for a good 30-40 miles hard drive and it was spot on, as its done is sat about for a little while
also i have done this conversion before into a mk2 fiesta exactly same engine and set up so i know it all works and works very well, but i just cant get rid of this weird engine misfire/lumpiness
if anyone has any ideas please let me know as im getting pretty desperate thanks again!!!
Old Jul 17, 2010 | 06:49 PM
Check the LOVE diaphragm in the carb.
Old Jul 17, 2010 | 06:52 PM
johnnyboy1987
sorry but whats the love diaphragm?? and how would this cause the whole engine to misfire/run lumpy?
JoeyBoyden
Jan 4, 2024 02:36 PM
martsmotor
Ford Focus Range
Aug 27, 2015 08:08 PM
JoeyBoyden
20
Aug 22, 2015 03:23 PM
coozer
Ford Focus Range
Aug 15, 2015 10:26 PM
Rickyrustyfox
Aug 13, 2015 01:11 PM
