Problem with high beam
Old Jul 17, 2010 | 05:56 PM
beller's Avatar
beller
Turb
Default Problem with high beam
Hi everyone,
I have a 89 rst and have a problem with the front left high beam not coming on but is ok on normal headlight, the rest of the bulbs and the right high beam are fine.
I done the bulb change with the same result and I tried jumping the earth to bodywork as was told a common problem with earth failing and I got the same again.
Is this a common problem? Ive read various similar problems but not the same.
Thanks in advance for any advice =)
Old Jul 17, 2010 | 06:20 PM
martysmartie's Avatar
martysmartie
Would think it is a live problem a broken wire perhaps, with a corroded earth normally it the light would be dim as not a good earth.
First thing I would be doing is checking you have +12V at the connector for it obviously with main beam on.
Martin
Old Jul 17, 2010 | 07:01 PM
beller's Avatar
beller
Turb
Talking
Hi Martin,
You were spot on mate, it didnt really click before that there are two positives running (obvious now!) and yes one has failed. Jumped high beam positives and bingo.
Thanks for the great reply and quick
Chris
jessie_rs
62
Aug 6, 2019 09:27 PM
Maxwell
Fiesta ST
Sep 13, 2015 05:31 PM
RSmark84
Sep 13, 2015 01:29 PM
little bram
Sep 10, 2015 10:45 PM
3doorcozmess
Sep 7, 2015 01:32 PM
