Mondeo TDDI Fuel Pump Help.
Old Aug 1, 2010 | 07:30 AM
jfnd's Avatar
jfnd
Default Mondeo TDDI Fuel Pump Help.
Hi everyone I have a 2001 TDDI 2 litre Diesel estate. Engine cutting out due to malfunction of fuel pump under car at drivers side. Fault located by breakdown service after careful checking from Filter back to tank. Electrics to pump checked as OK but pump only worked intermittantly after careful persuasion (with Hammer ) I intend getting pump changed tomorrow, but wanted to know if there might be any problem with coding from new pump to immobiliser if not done by Ford. Breakdown service declined to do work and advised that this was a "dealer only" job after confirming car had a trip computer. I also wanted to know if there is a filter in the area of this pump and if flushing out the pump and filter(if present) might work
Any other advice would be welcomed.
JFND
Rob Wells
Ford Mondeo Including ST
Apr 18, 2023 12:19 AM
JK12
33
Apr 26, 2021 12:09 PM
15
Oct 7, 2015 03:43 PM
cossirob
Sep 3, 2015 09:17 PM
andrewmctiernan
Wheels and Tyres
Sep 3, 2015 08:22 PM
