ST170 Dreamscience HELP..!!
Old Jul 20, 2010 | 06:49 PM
zobo1982's Avatar
zobo1982
Default ST170 Dreamscience HELP..!!
I have a 02 plate Ford Focus St170 and purchase a second hand Dreamscience stratagem. I checked out the straagem and all seems fine with 5 lives and in stock mode.
First, i plugged in and checked dtc codes, none found. Then checked the cars current ecu software version, which came back as ver 3.
Then i went to install the dreamscience software, all was working well then it failed. I tried to go back to stock and it keeps coming up with failed.
Now the car wont start or turn over or anything. I have checked what i think is all the fuses in the car and all are ok. The dreamscience kit wont even read codes on the car now. I have been able to use the dial gauge to check the codes and it comes back with D262 which i beieve is saying there is no milage etc.
Please help as i am afraid this is gonna cost a fortune....
Old Jul 20, 2010 | 06:59 PM
RSargie's Avatar
RSargie
first port of call would be dreamscience, id give them a ring first befor i do anything. failing that id disconect the battery for half an hour and make sure the dreamscience unit has no power? does it have battery's etc??? then start again.
arkeye
Ford Focus ST
Feb 20, 2016 01:22 PM
Sp3no
Sep 27, 2015 07:23 PM
Marv888
Sep 26, 2015 03:44 PM
Andypandy260
Sep 23, 2015 10:28 PM
richierich1986
Sep 18, 2015 03:29 PM
