XR4i Stalling and not starting
Old Jul 6, 2010 | 07:24 PM
The Angry Spider's Avatar
The Angry Spider
Default XR4i Stalling and not starting
Hi, just got a P100 with XR4i 2.8i rnning gear and the bloody thing keeps cutting out when hot and not starting again.
I've changed the fuel relay for a different problem but this has no stopped this issue -
Is it more likley to be the crappy auto choke or something else?
It starts fine in the cold but not after about 5 minitues of driving, need to leave it for 10 / 15 min till it starts again, sounds like the battery's flat when you turn it over. Then, it'll just start fine.
I have disconnected the cold start and what I think is the ECU temp sensor and it seems to run better.
Cheers for any thoughts - Jon
Old Jul 8, 2010 | 11:30 AM
I suspect the timing is out a bit, so do a dizzy swing, a slow starter esp if any kicking back ?, points to too far advanced, but swing for best setting then check co, and adjust if necessary, the 2.8 is totally mechanical no ecu it could also just be a lows et idle speed so raise a bit, few things to think about.
Rob Wells
Ford Mondeo Including ST
Apr 18, 2023 12:19 AM
DixieTheKid
11
Jun 6, 2020 11:20 AM
xrmalin
Sep 13, 2015 06:52 PM
natehall
Ford Focus (All Models)
Sep 8, 2015 05:13 AM
stevierob
Sep 7, 2015 07:09 PM
