anyone good with electrics
Old Jul 19, 2010 | 11:11 PM
ryan wilson's Avatar
ryan wilson
Default anyone good with electrics
iam currently doing a implant using a 98 zetec engine but iam not getting a spark i think it is something to do with immobilser but i do not have the key so i will need to get a brain with no immobilser so i can start it on the push button start
Old Jul 20, 2010 | 01:34 PM
martysmartie's Avatar
martysmartie
Yes you need a key paired to the ECU, (Assuming it's Zetec EEC ECU) there is a red PATS LED (If you have it) this should extinguish once the ignition is switched on which in your case it won't as it won't have received the code to disarm.
You can get a key programmed by Ford from the S/N IIRC, this can then be stowed behind the dash etc, so long as near the receiver, this would be a cheaper option than aftermarket management.
If it's a road car which I am guessing it's not it would void your insurance without a immobilizer as the standard car would have done, unless otherwise informed!
You can still have a push start in any case.
Martin
markk
Dec 2, 2021 06:59 PM
cameron2
12
Sep 4, 2015 01:34 PM
hopper350
Sep 4, 2015 12:53 AM
