crank pick up for escort rs turbo engine
ON THE ROAD AGAIN
what sensor do you use in a erst engine? i have a late style block with the hole ...and was told xr2i frst would fit but the sensor is too long and fouls the flywheels by about 10mm
do i just space this out ?
or anyone else used a erst block with cps hole ....what did you do ???
thanks
tommy
thanks
tommy
Zoggon
10-08-2015 10:39 AM
lockie
31-07-2015 10:03 PM
