2001 mk5 fiesta no spark
hi guys got a 2001 mk5 fiesta flight
its a 1300 engine
it has no spark on cylinder 1 and 4 ?
since the fault i have changed
coil pack
spark plugs
new leads
and still no better off car does run but very lumpy
and under powered
and the management light is on
does anyone know of any other thing that can be causing this
someone did say the ecu could be fried but if this was the case
would it still run ?
can anyone help ?
thanks kev
its a 1300 engine
coil pack
spark plugs
new leads
and under powered
can anyone help ?
thanks kev
Have you tried resetting the ECU and are the cooling fans on?
EEC has a strategy for running two cylinders it's something like this, if it detects overheating (even know it may not be physically) faulty sensor etc the remaining two act as an air pump to help cool the engine, if in LOS it may do a similar procedure.
Martin
Martin
I had that once on a 1.25, turned out after alot of head scratching and checking the circuits the lambda had shorted earth to body, shorting out the coolant temp sensor making it work in reverse telling ecu hot and cold at once!!!!!!! then it missed how you say above.
changed the lambda and new cts, reset ecu and it ran alright.
sridgett
Oct 1, 2015 07:30 PM
Steve Escos
Oct 1, 2015 06:57 AM
deathrider666
Sep 28, 2015 06:12 PM
