Trouble with TDCI 130 engine cutting out.
Old Jul 29, 2010 | 09:46 PM
Mikeyo's Avatar
Mikeyo
Question Trouble with TDCI 130 engine cutting out.
Hi all.
I have been having a problem with my engine cutting out. When the car runs it is great. It starts first time with no noise or chugging or smoke. The problem is it will run for a couple of hours or a minute I just never know. The engine diagnostics has shown up the following DTC's P1211 and p0251. The mechanic looking at the car has done a leak off test and doesn't think it is the injectors. He doesn't think the problem is the fuel pump as the live data shows the pressure running right up to 1400 bar. So far he has changed the following :- Cam sensor, Fuel rail and sensor, and the inlet metering valve. Tonight he is checking the wiring harness for any shorts or bad connections.
Does anyone here have any experience of a similar problem or have any suggestions as to what to try next.
Any help or suggestions gratefully received as I have had two weeks off work already and can't afford to be off too much longer.
Old Jul 29, 2010 | 10:31 PM
Lloyd's Avatar
Lloyd
escort mk4 cossy 4x4
p1211 =
icp not controllable,pressure above desired
these engines have problems with the camshaft position sensor,normally puts the glow plug light on and cuts out the engine, they are around 15 quid to buy. you may have fitted a faulty one
Old Jul 29, 2010 | 10:36 PM
Mikeyo's Avatar
Mikeyo
Is there any way to check if the sensor is faulty it was a new one from my local ford dealer.
Thanks for the reply.
Old Jul 29, 2010 | 10:37 PM
Lloyd's Avatar
Lloyd
http://www.thedieselstop.com/faq/949.../ecsd/icp.php3
Old Jul 29, 2010 | 10:43 PM
Lloyd's Avatar
Lloyd
faulty icp sensor can also cause the engine to cut out
Old Jul 29, 2010 | 11:30 PM
Mikeyo's Avatar
Mikeyo
Hi Lloyd.
where is this located the mech has replaced the fuel rail and sensor is this the same one?
gchristophi
Aug 31, 2015 10:36 PM
JoeyBoyden
20
Aug 22, 2015 03:23 PM
ar4ibaldo
Ford Focus ST
Aug 18, 2015 04:24 PM
Bailes1992
Aug 16, 2015 07:14 PM
