oli light on at idle?
Old Jul 28, 2010 | 05:19 PM
H.RST's Avatar
H.RST
Default oli light on at idle?
Hi my oil light is flicking on and off at idle when hot, oil levals ok no leaks 800rmp
got an oil pressure display witch is reading 4ish lb# when hot and 40 lb# when cold at idle? it will go up when reved?
not sure if its oil grade or pump on way out?
Old Jul 29, 2010 | 08:25 AM
4lb when hot, jesus that's low, I'd swap the oil right away, is the car high mileage ?, may just be getting very worn or shit oil, try a thicker grade ie a 50 instead of 40 etc if it's got loads of miles on it, will help the pressure problem, don't need a huge amount of pressure at idle anyway, but wouldv'e wanted higher than 4lb idleally.
TPM961
Jan 15, 2018 10:50 AM
RSmark84
Sep 13, 2015 01:29 PM
Marino
Sep 12, 2015 11:10 AM
natehall
Ford Focus (All Models)
Sep 8, 2015 05:13 AM
routemaster
Sep 7, 2015 05:27 PM
