group a breather
Old Jul 18, 2010 | 11:42 PM
busa bob's Avatar
busa bob
Default group a breather
CAN ANYONE HELP? Ive fitted spec r breather with mirror image tank to my 3door an now car smokes like mad especially when stationery in traffic..If i remove hoses so its disconnected, smoke disappears!!..What am i doin wrong? Anyone else had this problem?
Old Jul 19, 2010 | 10:50 PM
Dan_RS500's Avatar
Dan_RS500
From what you have said it sounds like it is the vapour from it venting to atmosphere, which is really what you want. From the factory this vapour would be piped into the inlet tract and so eventually let out through the exhaust, but this is bad for performance! On the rally car we just plumb a pipe out the wheel arch, on road cars you can run a pipe down the tunnel past the passenger compartment. I have seen touring cars with the catch can just inside the rear bumper but thats a lot of pipe work. Basically its a case of piping the outlet some where you are happy with. Oh yeah and some tanks have a breathable cap too, in some cases this can be done away with but check first.
Old Jul 20, 2010 | 12:12 PM
busa bob's Avatar
busa bob
Default dan 500
cheers dan for your thought but smoke is from exhaust not vapour from breather
Nov 1, 2015 06:53 PM
IainRS1700T
Sep 25, 2015 06:44 AM
Shaunc
Escort Range
Sep 23, 2015 06:00 AM
beller
Sep 21, 2015 04:13 AM
kevin36
Sep 2, 2015 06:24 PM
