2.0 pinto ignition timing?
Old Jul 21, 2010 | 01:46 PM
boy-racer-1's Avatar
boy-racer-1
Default 2.0 pinto ignition timing?
its at 4 degrees at the moment and im geting a misfire and seems to hold back alot
its a 2.0l 202 block pinto with a vv carb that was previously on a 1.6
anyone know what i should be setting it at? as haynes manual doesnt seem to have any info on it
any help epreciated cheers
Old Jul 21, 2010 | 02:14 PM
I used to run around 8-10 degrees BTDC static, , just do a dizzy swing until it's best, or if modded etc adjust to suit your engine by adjusting the advance retard curve, bosch dizzies are easiest to do this on.
JoeyBoyden
Jan 4, 2024 02:36 PM
big_Rad
Sep 15, 2017 09:36 AM
Ben26
Aug 27, 2015 08:56 PM
wheelwizardrefurbs
Aug 6, 2015 07:40 PM
baz
12
Aug 4, 2015 10:01 PM
