mk4 xr3i vibrating issues
Old Jul 26, 2010 | 08:40 PM
well2sound's Avatar
well2sound
Default mk4 xr3i vibrating issues
Hi, this may be an obvious problem but my xr3i vibrates very heavily at around 70mph. i noticed it after buying it and driving it home, the front wheel was severly buckled so i moved it to the rear. I assumed this was the problem but have also noticed a small notch about 7mm long and 2mm wide on the longer drive shaft, do you think that when this notch was created it caused the drive shaft to bend and thus cause the severe vibrating or is it down to the buckled wheel? thanks
Old Jul 29, 2010 | 08:13 AM
Need to get rid of the buckled wheel asap.
Mark_
14
Jan 16, 2016 05:27 PM
stephenb4506
33
Oct 2, 2015 06:25 PM
SMILER258
Sep 28, 2015 09:04 AM
talon1
Sep 15, 2015 10:27 AM
