renault 5 tdc sensor
Old Jul 17, 2010 | 05:20 PM
Phil2002's Avatar
Phil2002
Default renault 5 tdc sensor
sorry it's a frog.
does any one know if the renault 5 turbo tdc sensor uses a 36-1 trigger????
cheers,
Phil
Old Jul 17, 2010 | 06:45 PM
The 5/9/11 TURBO use the CJ1 engine, which is indeed 36-1, pattern, there are modified parts available after problems, alignment can be up to 5 degrees from exact as ecu can adjust this much.
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
Nov 1, 2015 06:53 PM
Mark RS
Oct 12, 2015 06:01 AM
fordrallycar
Sep 30, 2015 07:57 PM
stevecfrst1
Sep 30, 2015 05:18 AM
