- Why are maps with big boostspikes so common
- sorry, help again...seem to recognise this black saph...
- 3dr rear lights
- ecu wolf
- Q. Upgrading internals.?
- aeroquipping fuel lines
- putting car back together
- rebuild parts off ebay, cheaper but reliable?
- 2wd cosworth/not cosworth steering rack
- Sierra sideskirt bits - help!
- Ecu resistor wattage
- reasonable price for a strengthened Diff
- saph rims?
- Bolt & Nut size?
- 3 bar map sensor question
- Name that part
- few questions, oils and pressure
- Advice needed please
- Ford rs 500 shell
- long stud kit
- Cosworth rear Reyland brake info, what size wheels?
- Gearbox reconditioners ?
- 3dr heater fan
- alloy mounts
- a-pilar molding
- 2wd cosworth Fuel Pressure Regulator?
- 4WD to 2WD
- Cosworth clutch upgrade advice please.
- 2wd saff stereo wires
- clutch quadrant help plz
- spacer or plenum
- t38 poll
- Weber Cosworth FPR
- How many of you guys run 400+ bhp on std. MT75 box?
- Anybody know this big power saph?
- airbox question
- side mouldings for 3 door
- Saph 4wd brake upgrade options
- differant t38's
- cosworth poly bush set fit standard sierra?
- What's your opinion about this setup on sapphire 4x4
- t38 turbo's
- stage two saphire with std exhaust will it work
- cossie idling too high, any ideas??
- Fuel Pressure Regulator
- diy intercooler water spray? worth it?
- Lookin for a bumper
- Front crankshaft seal?
- morrette sapp cos question
- Duratec into a Sierra?
- two question about fusebox.
- turbo identification?
- iacv question
- engine specs
- sierra cosworth 4x4 gearbox differances,early,late spec
- ABS Sensor
- Inlet differences
- Head porting.Where too,how much?
- Thinking of buying a 3 dr Sierra Cosworth ,advice needed
- breather system options...
- cos 2wd engine mounts
- creaky steering wheel
- 3DR/RS500 bumper insert
- Cosworth Brake help needed!!
- sierra no brakes and air sound from pedal?
- radiator question.which 1??
- Dohc camshaft pulley
- side exit exhaust
- 4x4 prop problem
- Few 4x4 problems
- Chassis Mount Kit
- Would this fit into a 7.5" Cossie Diff?
- cosworth 2wd wiring loom problem
- 4x4 saph ecu location?
- remap due to head skim
- help
- Bottom end.??
- gearbox internals
- Is this???
- what next
- can anyone help me
- Big bhp=tramping
- headlining retrimming
- wats better 4x4 or rwd
- any disadvantages of using a 2wd water pump instead of a 4x4 item?
- wheel studs/nuts
- carbon mirror covers - sapphire
- Hub Removal
- Saff cosie 4x4 spark plugs
- 2wd cossie engine mounts
- sapphire pics req
- who uses there cossie everyday?
- sierra 3dr rear numberplate panel
- Homemade turbo heatshields
- Big Spec XR4i-Turbo Engine & Running Gear
- Rouse 250-R??
- Suspension differences 4wd to 2wd
- L8 Closed loop or not?
- Sapphire Cosworth Light Bulbs
- Help needed...mk1 frs brembos onto 2wd saff
- Limited Reprint: How to Prepare the Sierra for Motorsport
- Fuel feed to rail
- 200 block
- Fuel rail and Thermostat question
- AR.60 Garrett AiResearch T04 Turbo - Is this a genuine RS500 T4 ? with PICs
- Quaife 6 speed sequential gearbox
- the sound of missfiring/det?Vid inside
- GT30,external wastegate on saff? problems!
- oil leak 4x4
- 3 door rev counter and boost, now fitted in saph clocks
- Saff front bumper
- YB HEAD
- 2WD parts for 4WD different?
- will they fit?
- your thoughts please
- 360mm brakes on 2wd cossie
- RS500 Intercooler power levels
- sapphire original engine bay decals....
- Help !!
- Msd Antilag
- Handling bits for a cossie, whats avalible?
- 2WD Head whats it worth
- E903 MMM - Now back on the road!
- dodgy rev counter
- fuel pressure regulators
- valves in head
- Cam cover OEM colour
- BD16, would it work ?
- steering rack
- any guides on hiding loom in YB?
- tappets and few other questions
- Whats your 3 door ride height ?
- Inlets... Advise needed
- not the best wether for a cosworth
- Core plug fitting?
- 300mm 2wd discs
- who knows this company?
- Cosworth seat material supplier
- 200 motorsport block
- oil / engine breather advice
- Boxless exhaust
- cossie brake discs need upgrading
- clear or frosted back lights for sapphire
- New VIN Plate Needed
- turbo oil feed
- 4WD cooling for 2WD
- FRS Brembo's to a saff...
- cossie will not fookin start...
- Alternator 3dr cosworth
- Something different to 'stand out'
- OAP Pete...just to say..
- Cosworth sierra 2wd Cams (wich is wich)
- Correct oil for 2wd gearbox?
- Standard Boost Gauge??
- Cossie fuel tank pipe
- sapphire 4x4 and 2wd differances in here
- A simple YB tuning guide :)
- The YB Turbo Thread! :)
- Oil choice /daily use
- volts gauge off fuel pump wiring?
- Injectors not opening
- advice for winter time
- Some parts I am looking for
- Thread direction for front and rear axles
- Are 2wd and 4x4 rear brake dust guards different?
- 4x4 and 2wd fuel rail lugs?
- where to buy?
- DIY guides In here Please! mods make a 'how to' section maybe?
- pic request 3 door engine mounts
- Bump strips or not? (pics)
- Where to fit an oil temp sensor?
- front splitter?
- check your oil breather bottles
- Group A air filter question
- 2wd Saph Headlight wipers
- 4x4 spah cossie power
- YB oil pump
- big brakes wheels
- What it worth??
- fuel problems
- 2 wd brake resivior bottle
- New Coil
- Carpets
- opinions on spec
- Wheel bearins
- Radio wires?
- What T34 housing is this. .55 or .63 ??
- holset turbos
- Manifold fitment
- sapphire TCA's
- coolant tank question
- BD14 idle and emmisions
- aftermarket ecu's
- Are these sierra rear springs? (pics)
- 400bhp but what fueling?
- Mahle Pistons 2wd sierra cosworth
- Fuel Pump to Filter Fitting
- Cossie ABS light
- HELP
- cap cap torque setting
- .63 turbine housing
- My new Moonstone Blue 3 Door Cosworth (better pics)
- Oil pump gasket?
- anyone supply manifold flanges ??? yb ex
- Fitting cam & lifters
- Help with breather port locations
- engine loom
- Saff wheels
- modding the amal valve
- Coilovers and Koni's??
- 3dr cossie driveshafts/ sapph
- Saff electrical problem
- cosworth fuel lines,tank sender questions
- cosworth denso coil on plug upgrade
- external wastegate
- Missfire sierra cosworth 4x4 on boost
- welded diffs
- Sapphire cosworth gas bonnet stays...
- anti lag / lc switches
- Pressing Polybushes out.
- Water hose between heater matrix & head when using oil cooler sandwhich plate?
- Fuel swirl pot for track car questions
- Power Steering Hose
- how much torque do the crank and conrods take?
- Suspenion question
- Need 205 block facts
- headlights
- Refitting the engine, gearbox and diff in 2wd sapphire
- Electric Sunroof Woes
- inlet cam ?
- ECU's
- Ebay chips?
- cross member
- ABS
- what hid kit or bulbs?
- sapphire pedal rubbers
- Does this fit ? Help wanted
- granada interior in a saph???
- Cossie bumper stripping
- YB 80mm crankshaft
- Standard cams
- Moonstone 3 Door Cosworth
- T5 gearbox exchange
- Engine Rebuild- longer rod/shorter piston
- 4wd saph driveshaft/engine mount issues
- converting my 4wd saph to 2wd help
- Sapphire cosworth front seat subframes
- 3dr door
- Torque of the devil
