PDA
View Full Version : Ford Sierra/Sapphire/RS500 Cosworth
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 [24] 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72
  1. 2WD vs 4WD Front Wheel Hubs
  2. Recaro seats swop
  3. Fiberglass 3 door kit suppliers?
  4. T5 shifter
  5. AGPR 902P or denso irridium IK27
  6. P100 2.9 v6
  7. Cylinder head testing
  8. Bara gearbox rebuilds
  9. Aux water hose kit - oil modine
  10. lowering compression
  11. Pro alloy breather/mirror image
  12. Granada front hubs same as 3dr cossie ones
  13. Rocker cover gasket, whats best?
  14. ABS sensor/Brake wear sensor front suspension strut clip?
  15. Searching piston & longer rod packet (YB)
  16. 2wd petrol flap gasket
  17. Cosworth YB 2WD – Coolant system
  18. Front hubs
  19. general engine loom questions
  20. 3dr ignition switch cable
  21. 4x4 saph front springs
  22. ECU indentification
  23. Gearbox mount thread
  24. can a cosworth water pump be rebuilt
  25. GT30 water feed piping advice
  26. cosworth v's xr4i front shocks
  27. Standard Rev counter in 2WD Saph
  28. 2.0 dhoc turbo???
  29. saff cossie 4x4.T3 turbo
  30. Alternator Issue ?? I'm puzzled
  31. Flushing the full system on a 4x4
  32. Airtec intercooler
  33. Fuel Pipe leakage
  34. skirt rivets
  35. differential
  36. 2wd ecu on 4wd car
  37. Waterhose size
  38. Dead Turbo...
  39. Cosworth exhaust manifold to elbow gasket
  40. saff cossie door mirrors
  41. prefrences on cone or performane panel filter??
  42. Sapphire battery clamp
  43. Hex prop donut
  44. A17 AHF white saff, upto2001???
  45. air filter housing diffrence
  46. 2wd rear caliper thread size
  47. Saff Cossy ?? Dead or alive
  48. Sticky caliper
  49. struggling to start??
  50. Coilpack location ideas?
  51. help! need wiring loom grommet...
  52. Which fuse for central locking??
  53. What disks and pads????
  54. 2wd saph diff
  55. difficult gear change 4x4
  56. rev counter and fuel guage problem
  57. sapphire indicator lense
  58. 4x4 Suspension
  59. Turbo Damber - Fitting Problem
  60. Can someone that actually knows clear this up for me?(front diff removal)
  61. 4 pot calipers
  62. Rebuilding rear calipers
  63. 3 Dr bumper question
  64. saff headlight wash wipe
  65. Gear gaiter
  66. What's the deal with Cosworth ABS Sensors?
  67. diff mount ?
  68. where to get used rims
  69. Heater Matrix on a sapph?
  70. Bad vibrations
  71. Rebuilt Kit for MT75
  72. 6 Degree Rear Beams
  73. 2 x Screws for the rear of a 3 Door roof lining?
  74. moonstone 3 door, registration D36NWL
  75. Red inner wing clip
  76. RS500 T4 or Escort T34
  77. 3dr fitting kit
  78. How to replace original Sapphire Cosworth 4x4 stereos for aftermarket model?
  79. New here and driving an Sierra 4x4 Cosworth and A Escort RS Turbo in The Netherlands
  80. Wheels???
  81. Crap voltage, help?
  82. sunroof
  83. 2.o zetec in a mk1 sierra
  84. Map Sensor, Wiring help ?!?!?!?
  85. Radio Comms in the WRC cars of the 80's
  86. what colour is this car
  87. Strange overheating issues
  88. Ebay ISCV
  89. Saph 4x4 CV Joint Save??????
  90. New Airtec Product Offer!
  91. Diesel sierra rev counter?
  92. Cam cover refurbs, who does these at a good rate?
  93. uneven afr
  94. Anyone know the clutch plate bolt size and length? Better still, has anyone got any?
  95. cossie gearbox question
  96. 2wd saff cosworth fuel pump
  97. cosworth head gasket
  98. Cosworth Pistons / Head rebuilt
  99. mk1 sierra pinto anti theft
  100. Tap Tap Tappy noise
  101. cosworth sump plug size
  102. No boost
  103. Feeding oil pressure pipe through bulkhead where?
  104. Sierra (bolt-on) driveshafts positioning
  105. Looking for 18 inch comps
  106. skyline front diff
  107. Xenon Kit
  108. central locking relay 3dr position / + or - steered ?
  109. cosworth suspention bolts
  110. Removing 3dr rear windows
  111. cossie rear beam system,where?
  112. Cosworth Turbo's and water cooling??
  113. Dump Valves
  114. Pectel T2 ECU and wavering Tacho
  115. Where to buy these?
  116. 4x4 throttle position sensor
  117. billet swedish plenum
  118. Shows for 2012 - 3 Door displays
  119. Spotted today
  120. 2wd Sierra Engine mounts
  121. Adjustable strut tops - anyone seen these before
  122. Anyone know this saph 4x4 ??
  123. misfire@1500revs when cold
  124. Door strips
  125. Glovebox clips?
  126. AP or alcon clutch?
  127. Fitting alarm to Sierra
  128. P100 - Electrics HELP PLEASE
  129. 6 degree beam reversing problems!!!!
  130. Group A coil wiring up ???
  131. 2WD wiring loom connections ??
  132. Wire where does this go 2wd loom ????
  133. Ford press car H527 KOO
  134. Clutch release arm
  135. Pectel management, Anyone good with it in the south west??
  136. What to do
  137. Electrical Gremlin...
  138. breather on stg3 car?
  139. Larger Intercooler.
  140. A piller boost pod
  141. T38 r/b owners
  142. Exhaust manifold
  143. Sapphire Cosworth Steering Wheel + Electric window problem + CD player...??????
  144. 3 door seat belt
  145. Running Closed loop: Little bit of hunting at idle?
  146. MK1 Sierra Body Panels
  147. 4x4 cosworth exhaust manifold
  148. after some advise
  149. new here and 1st cosworth rep build :)
  150. Petrol Tank (Race type) Wanted
  151. non sodium ex valves and .48 ex housing ?
  152. P100 YB Cosworth
  153. Conrods?
  154. welded diff pics please
  155. Oil
  156. Gasket between turbo and manifold, who uses one?
  157. Billet main caps on 200-block
  158. Performance air filter myths.
  159. front driveshafts
  160. T34 "hybrid" Turbocharger Querys
  161. If you're after a new Fuel Tank look no further
  162. 2wd drive gearbox no speedo drive
  163. any pics of saphs on rl7's
  164. 2WD sapphire alternator - which make
  165. whats the best saph off sets
  166. New Wheels for my 3 Door
  167. 6 degree rear beam with Magnex exhaust
  168. Massive thanks to Paul at RS Spares.
  169. who is the cossie owner with billet blue cam cover?
  170. refurbished rocker cover
  171. Multipoint Saff rollcage...
  172. Engine loom recon
  173. Headgasket Thickness
  174. 2wd will not start
  175. fuel filter outlet thread? size?
  176. Brakes....
  177. Favorite sierra cosworth. Sapphire/3dr/RS500
  178. which springs for 4x4 saph
  179. What would the wife say!!!
  180. What discs are best
  181. 4x4 Cosworth against 2WD Cosworth (comparison)
  182. 2wd hydraulic clutch how/what/ where from
  183. removing fuel pump connectors
  184. saff cossie rear sub frame/axle.
  185. cosworth rattle/ticking/knocking
  186. Gas gold spring rates ?
  187. cosworth 2wd
  188. crank case vacuum !?
  189. Are 3 Door Sunroofs the same as Sapphires?
  190. Saff rear tyre sizes on 18"?
  191. Sapphire wheels
  192. Steering column bush
  193. 2wd saph loom are they same as 3door loom??????
  194. Questions! Jummie ones i guess.
  195. lattice or shark tooth
  196. A few pics of my car!
  197. where's best value to buy sodium filled ex valves , valve springs and head set
  198. 2wd to 4wd plenum
  199. Heater resistor...
  200. Metal Water pipe issue with GT30
  201. broken CV joint?
  202. Cylinder head port volumes and lengths
  203. head gasket help!!!
  204. replacing water on a 3dr were is the air screw ??
  205. 8x18 et32 on a saph?
  206. 4x4 gearbox?
  207. Merkur XR4Ti aka US 3 door Suspension help
  208. Couple of problems
  209. RS500 Airbox scoop
  210. why will my sapphire only run with plug leads wrong
  211. engine noise when warm??? idears plz???
  212. How to remove this part of the dash…
  213. 2wd oil pump
  214. gpa engine spec
  215. How to tell if its a genuine Saph cos carpet
  216. Main & Big End Bearings/Shells. Who' are best?
  217. doorcards
  218. amp replacer panel
  219. Bump Stops.
  220. S8 ecu wiring
  221. t34
  222. brake question
  223. Radiator fan fuse location? For MSD fan loom install
  224. Need pic/sizes of rear rose jointed trailing arm
  225. front wing holes
  226. New heated windscreen
  227. help needed on wheel choice (rs7) and offset
  228. Show us your braces
  229. Power steering
  230. Radio/equalizer blanking plate thingys
  231. 1984 2.8 v6 3 door rep help
  232. 3 Door vs Sapphire Brakes.
  233. gt28 on a cossie....
  234. 2wd + 4x4 top hose, is there a difference?
  235. T3 turbo expired
  236. Anyone with a 3 door help
  237. am I just a thicko
  238. New engine looms
  239. saph cosworth part prices
  240. 2wd shafts?
  241. Im reunited after 8 years.. and a road trip!
  242. New turbo
  243. v band
  244. saff cossie rear suspension arm bushes
  245. Swirl Pot Location Ideas
  246. 4x4 and 2wd front spoilers same or different
  247. 2wd boot badges
  248. Sierra V6 4x4 to Cosworth 2wd
  249. please can anyone advise on wheel et
  250. 2wd steering rack
