PDA
View Full Version : Ford Sierra/Sapphire/RS500 Cosworth
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 [68] 69 70 71 72
  1. fan problem on a 4x4 cozzie 330
  2. strange engine behaviour, any ideas?
  3. TAPPETS
  4. 17" x 7.5" rims on Saff - What tyre size?
  5. Refence map sensor 2wd ?
  6. wanted 3dr parts
  7. 4x4 cosy runing lean - any ideas?
  8. 4x4 oil pan leak? ?
  9. tyres rubbing
  10. Which brake conversion for a saph????
  11. 3dr price??
  12. Best S/S Exhaust for a 3dr Cossie?
  13. boot badges
  14. link to some pics of my car and new bits and pieces! UPDATED
  15. LSD or not?
  16. Breather claeaning help (2wd cos)
  17. Rear trailing arm rose joint fitting?
  18. What radio
  19. full beam stork
  20. Backfireing and cutting out
  21. what plugs?
  22. phase sensor,plug gapping and tale of woe.
  23. Texaco Decals
  24. 2wd black saph cossie
  25. can you still buy new cyclinder heads
  26. COSSIE WATER TEMPS ?
  27. "Search" feature???
  28. Black 1990 2wd Sapphire 80K Genuine miles (advise pls)
  29. Butyl cam shaft cover gasket
  30. defferences on YBG engines with and without A/C
  31. Sierra 2.9 efi 4x4, changing torque split
  32. My 1st Cossie!!! What do ya think???
  33. Help Relay prob on my 2wd saff
  34. rs 500
  35. bushes
  36. saph window tints
  37. 2WD Saph Cossy Fuse Box
  38. timing belt
  39. uprated fuel pump?
  40. Cosworth exzaust heat shields ?
  41. What plugs for a Stage 3 Saff?
  42. cam cover refurbishment ?? help
  43. Xr4i cosworth brakes
  44. 2WD COS PULLEY PROBLEM
  45. Best cossie specialist
  46. Sapphire Short Shift Gear Stick.
  47. heat shield ? where ?
  48. Part number or name for this????
  49. silversaph forum.....
  50. HELP!How much is a 3liter rs saph worth??
  51. 3 dr back bumper
  52. Compression ratios
  53. How many moondust saphs were made???
  54. Tappets on a 2WD Saph.
  55. 2wd cossie rear axle into estate
  56. which cossie oil
  57. Any way to find out if 2wd saff is low comp ?
  58. 4x4 cossie wont idle from cold?
  59. gearbox oil
  60. chips
  61. 200 vs. 205 block and long studding.
  62. AP racing 4pot rear kit
  63. Tracking the Sapphire cosworth
  64. Carbon Fiber Parts for Sapphire
  65. RS 500 splitter question
  66. 2WD Saffs wanted for display
  67. stiffer anti roll bars
  68. oil pressure on 2wd saph???
  69. what a difference a day makes
  70. Sapphire Cossie Colours
  71. crashed my 3dr.
  72. Closed Loop wiring
  73. fitting 7 spokes
  74. Where in Germany to get front Gearbox rebuilt?
  75. cossie strut braces.
  76. Differences YBP EECIV Bare Head (T25) and Sapphire (T35)
  77. RS-500 Engine help!!
  78. Testing ECU
  79. What is better 205x50x15 tires ?
  80. coilovers
  81. removing escort cossie gear knob??
  82. 2wd Cossey - What maintenance checks and more power ???
  83. clutch probs on 2wd
  84. Sierra 3dr cosworth options?
  85. any1 know who owns the black rs500 i saw in grantham, lincs
  86. HELP!!!!
  87. change of my pump water sierra cosworth 4x4
  88. 4x4 saff cossie prices
  89. HOW DO YOU TELL A L1 ECU FROM A L6 ECU????
  90. Bailey Dump valve
  91. Oil Consumption
  92. ARP stud and nuts
  93. Questions, Questions, Questions. Help a new guy out
  94. Drawings for a bigwingsump on a 3 door?
  95. Cossie running problems
  96. ECU question
  97. Sierra 5 Drs. Front suspension
  98. rad fans
  99. Saph speedo cable
  100. car cover
  101. How much would you ask for this if you were to sell it?
  102. Strut Brace Question
  103. what block
  104. Respray for my sierra - magenta
  105. Rev counter on 4x4 saph
  106. White rear lights??????
  107. Cosworths Wanted For Ford Fair
  108. How long will my gear box last?!!!!!!!!!!!!!!!!
  109. any body got a flint grey saph with tinted windows??
  110. Where to get brake calipers refurbed ? ? ?
  111. The Ford Sierra 2000E
  112. MAP sensor loom plug information wanted
  113. saff cossie
  114. Cossie oil temperature
  115. Question for sapphs running xr4x4 driveshafts
  116. Carbon Fiber Carbon/Carbon grade
  117. carbon fibre door cards
  118. how much dose a cosworth weigh???
  119. Help and advice please.........
  120. Borg Warner T5 6 Speed Box & Rear Brake Caliper Upgrade
  121. Upgrade calipers for 2WD Sapphire?
  122. whats pectel all about???? (2.1 zvh engine)
  123. 200block, 4wd cilinderhead, 2wd car --> which oilpump?
  124. which plugs and leads
  125. hmmz lost it!!
  126. Front wheel bearing
  127. cossy cuts out....
  128. Best clutch for saff 4x4
  129. cossie running on 3...
  130. speakers
  131. "double bar" front strut brace for 2wd saph
  132. Manual adjustment clutch cable conversion
  133. 3Dr owners... how are your front aches held on?
  134. FAO all anoraks,Anyone heard of this make of exhaust?
  135. PARTS IN T34
  136. Calling all XR4X4 owners in South London...
  137. two stage boost
  138. 3 bar map sensor
  139. rondell 122s on a rwd saph?
  140. 2.8i water pump HELP
  141. Cam timing on saph!
  142. mt75 box conversion on to Pinto block.
  143. escos engine into 2wd
  144. Stage 3 - Pinking
  145. How much for a 3dr
  146. brake bias adjustment
  147. What Gearbox?
  148. Whats a Standard 4x4 Chip look like?
  149. cosworth from fife?????
  150. is the 4wd steering rack the same as the 2wd rack
  151. 2wd Saph Cos
  152. carbon bits for a cossie
  153. waterpipe diagram
  154. oil question
  155. 3dr chassis numbers(help)
  156. Air con/heater fan prob
  157. RS500 split rims
  158. advice on 3 door rs cossie
  159. saff blowing steam
  160. Escose Rims
  161. RS500 clocks in a 2wd saf
  162. Clear Headlights
  163. quick map sensor question
  164. T3 TURBO WILL IT RUN????????
  165. Clutch upgrade advice
  166. 3d Cossie bumper on Sapphire?
  167. Dump valve position.
  168. PLEASE HELP! REAR DIFF GONE BANG!!
  169. 4WD > 2WD conversion
  170. Standard clutch - how much power can it take
  171. Storing my sapph cossie for 2 years
  172. 380 bhp on Greens?
  173. SAPPHIRE DOOR MOULDINGS
  174. Fully Dressed cosworth turbo engine weight
  175. Why is there a power difference...........
  176. white 3door pics/info please
  177. 18" OZ Superleggera on a 2wd, will they fit???
  178. Cosworth Heads!
  179. sierra cosworth 4x4 gearbox !?!
  180. ****3 dr idle probs part 2....PLEASE HELP****
  181. Spark Plugs
  182. saff vs 3dr dash
  183. gearbox
  184. points on fitting a clutch cable please!!
  185. s2 to cossie
  186. REBUILD ADVICE?
  187. L6 OR L8 ECU DONT NO?
  188. Anyone seen C9SEE?
  189. The Best Exhaust for Cossie 4x4???
  190. Reading....preferably the Calcot area
  191. saff wheel offset
  192. Anyone need 3dr centre caps?
  193. Early RS500 engine ??????????????
  194. new engine probs!!
  195. are these the right end caps on my grey injectors?
  196. how many 500's left
  197. part no.s for bosch parts?
  198. weight of a shell?
  199. help plz
  200. ive just got my first cossy
  201. turbo prob
  202. unregistered RS500
  203. standard air filter on saph cosworth
  204. Is there a difference?
  205. what is the offset of a 2wd cossie wheel
  206. What's the best air-filter for cossie???
  207. Tell us your reg
  208. How many moonstone's???????
  209. 2wd Sapphire ABS problem
  210. OIL question - Magnatec in my Cossie?
  211. best poly bushes?
  212. best place to get rebuild bits?
  213. Help with stage 3
  214. Maximum iwdth rims on a Sierra 3dr
  215. Black dashboards
  216. What is a Marram shaft
  217. Valve pocketing
  218. LOOKING TO BUY A SAFF< WHICH SHOULD I GO FOR?
  219. How much to get a new head gasket fitted to a 4x4.
  220. what bhp with this set up?
  221. 3dr sunroof question
  222. Does anyone know................
  223. How much?
  224. rouse sport 304
  225. Cosworth 4x4 inlet camshaft (standard) NEEDED!!!!!
  226. 2wd front struts
  227. The New Road Tax Advert
  228. how much would you pay?
  229. super t,s or superleggras
  230. saff headlamp trouble, ( no dipped beam) common?
  231. Anyone knows this white Rs500?
  232. Tinted (black) rear lights for a 3door Cossie?
  233. Gearbox Troubles
  234. lowering a saff
  235. Easiest way to fit a 500 style cooler to a 4x4 saff?
  236. flow in ported head
  237. cozz suspension
  238. Cam Q
  239. What speed Rating ?????
  240. can a 2wd L6 ecu be replaced with a 4X4 L8 ??????????
  241. What rim and tyre size for a 4x4 saff?
  242. I keep hearing about piston slap??
  243. HOW MUCH?
  244. Broken rear wheel stud
  245. best wheels for a saff cossie?
  246. under bonnet pics
  247. What does a turbo damper do?
  248. So the STOOPID jacking point broke
  249. which colour
  250. Looks powerfull
