- Need help with my 2wd saph restoration!
- cosworth outer wing
- Revolution 17'' wheels for saphire
- is it just mine........
- advice on buying an Exhaust
- c pillar trim
- different interior pics - inspiration needed!
- pop pop bang????
- stupid washer jets
- Bleeding the brakes on saff?UPDATE!!bleed nipple is completley rounded off HELP!!??
- clutch question
- oil from air filter cone?
- rubber boot for 4x4 sapp cos TCA
- P100 rear axle
- What tyers
- my new exhaust
- Who should i use?
- best way of removing the pinstripe from the side of my saff??
- cosworth brakes disks/pads
- brakes system needs bleeding on my saff 4x4,whats the best way??
- 3dr Cossie chrome headlamp clips.....
- Big Breaks
- 2wd Cosworth handling terrible!!!!
- Superchips!
- Removing Door Mouldings
- koni shocks
- Whats the best lowering springs for saff 4x4 on escos rims??
- 2wd ABS sensors.best price?any cars have same sensors?
- fuel pump relay
- turbo technics
- Rousesport 302r sapphire 2wd white whats it worth!!!
- 184mm clutch plate questions
- Fastest Fords:a Century Of Speed Dvd
- Rs Brochure 1992/93 Edition 2
- valve stem seals
- fitting comp mo 18 8 to 3dr cosworth
- Saph Shells.
- Rebuild t3 (with 360 bearing??)
- Gasket
- cps gap?
- sequential gearbox
- Vibration at low revs . Propshaft ???
- Valuation.
- I week restoration!
- what exhaust for a cossie?
- Which siemens injectors work best
- Rs 500 boost hoses (what do i clean them with)
- 4wd 2wd Looms
- pic request of BIG TONY RS s saff please
- Spring questions
- brakes
- How easy is it to fit injectors?
- Gearbox oil
- cosworth door mouldings!!??
- Camber Problems
- front discs
- cossie alternator
- Carbon Splitter
- Front goodridge brake hoses
- rear ligths for 3dr
- Tool for 3dr bonnet!
- 3dr cosworth grill wanted asap
- chassisnumber and engine codes
- YB wire ring head gasket dilema
- Missfire @ 4.5/5k
- Saph water leaking into boot
- pipe from fuel filter to fuel rail
- Engine rebuild
- Need Inspiration!!!
- amal valve question
- Saff strut
- sapphire sunroof leaking
- 2wd TPS problem
- question?
- steering arm uj
- 2wd & 4wd springs?
- where can i get this hosing from
- Pistons hitting valves
- 3 Door ABS
- How to refit an anti roll bar??
- sapph interior
- Bucket seats in a 3DR Sierra
- wide or close ratio?
- cossie questions!
- Few cossie bits for sale
- another sparkplug question
- Starter motor only works when cold
- fuel pump re-wire 4x4 saff
- Breather removal
- cossy heaven
- widest tyre with arch mods
- little bit of a running problem after a ragging
- suspension question
- sapphire carbon airduct
- t34.55
- oil breather
- 4x4 engine mount
- Block drain plug
- Sapphire rear end bushes? Which ones?
- Centre speaker, 3 door. Which cable?
- central day
- Cosworth 2wd tuning basics please!
- another cossie problem
- sapphire of long ago
- question about 2wd/4wd clutches
- cossie suspension
- is it the correct position??
- 2wd exhaust manifold on a 4x4
- Saph Fog Lamp Surrounds & Mudflaps where from???
- 3dr headlamps
- saph rear spoiler
- boost controller
- what oil?
- fitting an oil pump?
- Turbo heatshield
- Karl at Norris Motorsports
- amal valve
- Cossie 4x4 Head Removal
- Is it the same offset??
- gauges dead..??
- Head Gasket thicknes and retorque head bolts
- How long can I expect HT leads to last?
- fitting koni's on a 2wd
- sapphire speakers!!! what ones?
- 3 Door fuse box
- ABS On my Saph
- cometic exhaust manifold gaskets
- Engine resonance at 4000 rpm
- vented bonnets
- 2wd saff & 3 door differences ?
- rear caliper slider pins 2wd ?
- still tappy after changing lifters???
- 1987 World Touring Car & The Escort Cosworth Story On Dvd
- 3 door buying advice please
- AFR problem with stage 3 chip
- Sierra Sapphire Powered By Rs 2000 (mk5 Escort)
- lights
- ecu loom
- low oil pressure!
- Tramlining worse on coilovers?
- Registration issues
- speedo and rpm counter needles
- ideas!!!
- fuel pump mnt rubbers
- 3dr tca's
- how much preesure should be....
- rally sapphire cosworth (newbie)
- Differential ratios
- Different Sized Tyres
- t4e to a to4b
- engine rebuild.
- help needed fitting k&n induction kit
- RS500 - missing lower spoiler?
- brake pads for cossies
- strange smoke
- inlet manifold runner gasket with ported head
- rev limiter????
- fuel pump and filter bracket
- Emergency! 2WD radiator needed in Wiltshire today
- Is it worth???
- Rocker Cover Replacement
- Garrett -31 vs -34 wastegate actuator
- head tightning down
- Starter motor and solenoid
- 3 Door Cosworth Wheels.
- Dizzy Auxilary Shaft
- 3dr wiring loom
- Cosworth Springs.
- cosworth exhausts
- Front polybush fitting?
- Racelogic traction control system
- Cosworth Re-Shell Questions
- Rear anti roll bar link rods..??
- tyre size for 18's
- Stainless water pipe question
- Rear Beam from zoo or Adrenaline?
- saff 2wd fuel lines
- Different car problem but....
- Turbo damper
- Rear hub nut size
- anyone running GAZ coilovers on a 3dr
- Steering knucke donut 3dr
- How to get rear beam bushes out?
- help !
- Exhaust what make is it
- clutch problems
- help setting my boost
- My Motorsport 500 Pics
- Bilstein 909 Coilovers
- Blue flame exhaust
- Anyone got a photo of a 4x4 box
- bailey dump valve mounting
- YB complete Gasket set
- Adjusting coilovers
- How do i change a rear diff mount????
- Went to the rolling road now the results
- Converting to L8
- J plate cossie floor vin stamp pic request
- Front strut top mounts
- Help with photos
- Calipers Fouling Wheels
- 140 then nothing ???
- secs monitors
- cosworth
- swedish manifolds
- mods
- This is how to correct saggy front bumpers with a fork lift truck
- idle speed control valve
- Long Studded Block
- paint or powder coat????
- AP calipers
- sierra 4wd cosworth breather & header
- Where does the ECU go?
- Front bumper....???
- oil pressure
- eec4 manifold
- OIl pressure gauge fitting problem. Please help
- Problem with the fans staying on on my saph 4x4,was ok last time i started it???
- Why is there only 1 page in this section?
- what plugs for cossie?
- hi guys new cossie owner
- anyone got G678 JHB ? magenta sapph
- cam belts
- Classic Car Insurance For Cossies?
- T4 turbo
- Gauge Mounts
- engine loom
- help fitting a 2wd cossie loom!
- Fan Switch :(
- Still Got A Strong Fuel Smell
- Petrol pipe
- whats the best spark plugs for my cossie
- T34 & T35 cosworth turbo
- 3dr starting problem
- 4x4 Saph Brake Pipes, original Oem
- piston
- 4x4 Bonnet Vent Brass Inserts
- Rear Anti Roll bar sizes
- 1/4 mile time
- xr4 coilovers and wheels???
- What offset do I need to cover 330mm 6 pots
- Strange tca..
- Different spring rates??
- How likely....
- how to remove...
- Pec high boost stock compression piston
- Please help me diagnose an engine problem with my Saph
- blown head gasket
