- Can a clutch be refurbished?
- Braking problem
- coil overs
- show me your sapphire boot installs
- torque settings
- what dvd player in a 4x4 saph dash
- wont idle
- standard 2wd sapphire diff ratio?
- loose front bumper
- jackin points
- CAN YOU HELP.
- Temperature Gauge Randomness
- Fiesta Cosworth suspension probs???
- 3 Door stage 3 conversion
- bailey tanks/ swirl pot
- sump.....
- Cam seals STILL leaking!!!!!
- stronger gearbox/diff etc.
- looking for info on Sierra CVH roller lifters
- rs500 inlet
- 2WD turbo heatshied ? Ally ones ?
- gauges
- wheel help
- ruud racing saph kit?
- 2wd saph gearbox rebuild. help please
- Dump valve's
- Does anybody out there know my new three door?
- wot oil??
- cosworth rocker cover
- Cosworth Mud Flaps
- How do you remove the exterior qtr trims from a 3 door ?
- Engine hesitating and backfiring when coming on boost
- Cam Belt Change
- miss fire
- Suspension shims
- What should i do
- DOES ANYONE KNOW MY CAR? G57 AOO
- Wheel offset
- Oil leak at front of cam cover 4x4 Saff
- Heater blower motor
- how much boost do you advise??
- Quick Question
- Did sierra cossys come with 4pots standard?? newby soz
- front number plates- what sizes do you have?
- Water Temp Sender
- Will an XR4x4 front cross member fit my 2wd sapphire
- garage warranty
- Compomotive CXN WHEELS for 3DR
- rs turbo engine in a sierra will it fit ?
- Saff cos 1993 standard alloys ££ value??
- Are these intercoolers any good
- whats the difference between a 2wd and 4wd engine loom?
- Oil Seperator?
- Compomotive wheels
- Idle control valve
- what is your top speed in your stage 1 saff???
- What spark plugs can you reccomend
- Rear Diff Mount
- Distributor cap and rotor arm..........
- Help needed ASAP please!
- I need help, what chip, injector should I run ???
- Hiding wires
- Philloy Products need pics
- Steering rack questions
- 4x4 cossie rear wheel bearings
- STAGE 1 OR MORE POWER?
- 4x4 bonnet carbon air vents
- Cossie clocks / white dials
- oil breather / oil seperator
- saff interior
- saphy throttle pot
- centra wheels
- New Cossie advice
- 4wd conversion
- Running and boost problems
- Saff 4x4 rear strutbraces
- How much bar load pressure with 300 BHP?
- Turbocharger number of revolutions with 1,5bar
- level 8 ecu
- help
- running MSD coil pack with autometer rev counter
- Original 3 Door Wing, Bonnet, Grille
- saff scorpion exhaust
- Photo of morretes
- cosworth Starting problem
- spark plugs
- cossie pistons
- pro alloy intercooler fitting ?
- Urgent Help Needed, ABS Wiring Diagram
- Saff Roof Liner
- interior trouble
- Exhaust manifold to turbo gasket?
- 2wd/4wd engine loom
- 4x4 saff gearbox
- Knackered wheel bearing cause discs to warp?
- Which is better 2wd or 4x4 exhaust manifold
- nearside front driveshaft
- 2wd Saph Tyre Sizes
- Saff bottom end rebuild advice please.
- Thinkin about Cossie ownership...
- mis-firing RS500!
- Piston ID
- lets see your cam covers
- new engine
- A good Brake Set-up for a Sapphire with standard 15"
- Crank Pulley
- 3 door steering question/help
- 4x4 rear wishbones
- Inlet Length on Sweedish Inlets
- how do you no
- parts.....
- Only 385 bhp.....!
- Escort anti roll bar
- what is this actuator
- where is the best place to get a 2wd gearbox rebuild?
- backlit saph dials- colour options?
- Pics of cossie's with mudflaps on
- Are there any internal / mechanical differnces between a ...
- Is the L8 ecu in a 1990 H plate 4x4 Sapphire ?
- fuel pumps
- just bought my first long awaited saff does anybody know it?
- standard airbox of group a filter
- rear wishbone bush`s
- length of cossie?
- Wheels & tyres for 3dr.
- Aqua-mist water injetion/intercooler spray
- Oil cooler recomendations???
- does anyone have a good 2wdsaph gearbox 4 sale?
- Grp A 3door rims
- taken the head off, what a relief
- size of rear driveshaft nut on cossie?
- Random wires
- Slight misfire
- FUSE BOX
- need some info,
- Which springs
- engine rebuild.........
- help/ photo required
- Setting up a -31 actuator, help please
- cossie clocks
- Mike Rainbird is ACE
- How Reliable Has ur Cossie Been??? (please contribute)
- help needed
- Suspension mods to 2wd
- earliest registered 4x4 saffs
- Amal valves
- Special tool
- Buying a Cosworth
- saff diff
- saph 2wd missfiring badly! help!
- Oil ???????????????????????????????????????
- Coil pack conversion
- fuel pump and vibrating
- Fitting polybushes 2wd saff
- Temp gauge fitting?
- YB/pinto bearings?
- rs500 intercooler and alloy rad measurements
- need a few inputs
- rs500 intercooler
- Oil Separator / Breather
- Fast Idling Probs
- "Cosworth Eater" Laugh, I Nearly Dropped My Kebab!
- P100 body
- good fast road engine spec???
- Head gasket thickness
- Not boosting Properly and Stutter.
- 3dr 8J & 9J tyre sizes
- higher or unchanged compression.
- Some cylinder head questions?
- flipping abs
- running on 3, clock flickering
- Where I can buy Sierra RS Cosworth bumpers & wing?
- bd10 cams and vernier pulleys
- BD10 Inlet - BD14 Exhaust ??????
- Alternative suspension pivot point
- Smoking Probs. Expert Advice Needed.
- 2nd Fuel Pump Relay In the Boot??
- Help ! starting prob
- DTM Mirrors for Sapphire
- Toyo 888's!! Track day guys
- xr4i
- Help with inside front Hubs on 2wd sapph PLEASE
- Help: Cossie fuelling hint??
- Air injectors
- Exhaust Valve - Where From
- Heated Front Screen Not Working?
- front mud flaps
- Fuel pressure
- SIERRA COSWORTH L6-L8 ECU
- 2 wheel drive compresion
- This is a new one!! Help needed!!
- blown head gasket, how hard to change it
- Any one running Super leggras on their Saff?
- Stock wheel and tyre Escort on rear Sapphire
- Bumper brackets.
- 4x4 Cosworth Buying guide???
- 6 speed gearbox options
- Cam kit for xr4i 2.8 v6 colonge
- carpet
- Standard lamps vs Morettes: your opinions thankyouplease
- Is It Common For Rad Fans To Be ON When RS500 Cooler Fitted?
- 3 door , skooshers prob
- power conversion to my westfield costs??
- 18' rondells
- Do they make 18" Rondell/Engells for 4x4 Saff
- I have a simple question, help please.
- Hydraulic Handbrake
- IS THIS A GENUINE 4X4 WATER PUMP???
- H reg 2wd Sapphire cosworths
- Pistonheads legendary cossies
- 2wd and 4x4 head differences and costs
- Electric to Manual windows, HELP !
- please help my saph is dead
- Cossie Problem
- Pic request, Mercury Grey Saphs
- mot ? will i fail if
- RS STEERING WHEEL BOSS
- front shafts on 4x4
- 2wd and 4x4 Master Cylinder the same?
- Broken Wastegate Penny
- 2wd manifold
- Koni Damper Settings
- rear beam bush
- 3dr Motorsport mirrors?
- coolant system
- What's wrong with my window?
- poly bush`s
- Any experts with abs pumps/wiring ?
- boost????
- COSSIE PLENUM
- Where can I found RS500 AIR BOX lid ? (tittle rewritten)
- saph elecmirror switches? are they the same in any other car
- 2wd cos abs vibrating pedal
- Bearing Greese
- Sparco Rollcage
- headlight wiper arm needed
- Anybody running RS7's with 215/40/17's/Koni's/35mm lowered?
- Pictures wanted
- XR4x4 front driveshafts for saff 4x4
- Saph 4x4 Cosworth Transmission Noise?
- water pump
- 2wd misfire
- does any bodey remeber this car ??
- stupid earth faults!!!!
- Can you still get the side door mouldings for a 2WD Saph?
- which stage 3 chip?
- FUEL PUMP RELAYS????
- RS 500 Plenum
- What Will +0.5mm Pistons Bring My cc Up By/To?
- Valuation Please - Ebony 1991 J Sierra Sapphire Cosworth 4x4
