PDA
View Full Version : Ford Sierra/Sapphire/RS500 Cosworth
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 [19] 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72
  1. Washer location in cosworth rear beam?
  2. 4wd coilovers onto 2wd?
  3. Question for YB engine builders
  4. Databases
  5. cosworth cambelt set up
  6. Diameter of 2wd Cos front ARB
  7. Opinions and thoughs needed lads
  8. Tyres
  9. 88' Sierra 2.0i fuel pump not working
  10. Sierra cosworth distributer voltage help please
  11. MSD diff mount...bolts to long?
  12. Cosworth head porting
  13. Which Clutch
  14. top mounts
  15. Can you still get genuine header tanks from ford?
  16. 24v FBC advice
  17. 2WD sierra cosworth ecu
  18. Cos eng running in
  19. Fuel Rail Refurb
  20. Trim plate
  21. Airtec Cosworth Turbo Cooler *One Off Price*
  22. block
  23. Autocar mag - Sierra Cosworth
  24. 3dr tailgate striker post
  25. Turbine housing
  26. wasted spark
  27. 4x4 Pulleys
  28. cosworth steering rack whats best
  29. sapph cossie kit, whats it worth?
  30. why u should do a good hpi check
  31. Has any one got a 100% std white 3 door cosworth
  32. Gave the sapphire a clean today
  33. Front Strut Bearings
  34. 2wd cv joint question...bear with me...
  35. 3dr level sensors
  36. A strange one, Please help!
  37. Breather plumbing
  38. buying pistons
  39. Sierra Cosworth Brakes go hard
  40. Ignition Lock
  41. Escort cosworth twin bar strut brace
  42. How to time up phase sensor when fitted to camshaft
  43. Oil pressure light fault
  44. Gas strut that fits boot and hood Sierra 4d
  45. changing the sapphire diff mount
  46. 3dr sound system
  47. Replacing OEM standard radiator
  48. Cossie recent photoshoot
  49. Pics of seam welding pls???
  50. 4x4 standard exhaust ??
  51. Escos and 3 dr ambers and fogs the same?
  52. standard alarm in sapphire
  53. Quick bumper question
  54. Aircon for Sapph wanted
  55. rev counter
  56. Sierra Cosworth front abs sensors
  57. Running issue
  58. Bulkhead brake pipe colour
  59. the start to my darkened interior
  60. Power steering Sierra
  61. Little help identifying some bits...
  62. Non abs with 330m brakes
  63. tca length 3dr cosworth
  64. 2wd sapphire turbo queries
  65. Front castor issue , 3dr cos
  66. Anyone bought at set of these for a 3 dr?
  67. Hyraulic handbrake question
  68. 2wd & 4x4 thermostat
  69. Gaskets on 2wd cos exh manifold
  70. 2wd or 4x4 diff
  71. Back to a cosworth with a few ???
  72. real notion to buy a cozzy
  73. ΥΒ crank scraper
  74. 2wd manifold spacer were from
  75. engine bay bling
  76. 3 door engine fan fuse
  77. Did wonder why I have so much understeer lol
  78. 3dr Side Repeaters.
  79. 3dr Rear Light.
  80. diffrence between 4by and 2wd
  81. Dash Repair
  82. 3 door alternator help
  83. D700 0PP anyone know any history
  84. How much was it to upgrade to leather interior on 2wd cossie?
  85. Cosworth vacuum pressure.
  86. sapphire cosworth door mouldings
  87. RS500 Heat Shield.
  88. best way for attaching 3 door wheel arches
  89. 3 Door course car
  90. Help - my local Shell Garage has gone
  91. Cosworth over revving at idle.
  92. "lui" RS500 touring car,
  93. cosworth lambda sensors.....
  94. cosworth vibration!
  95. What 3" exhaust for 3dr?
  96. 2WD Saph's distributor cap loose
  97. show me your black sapphires
  98. Where can I get some 55lb black injectors
  99. external wastgate pics please
  100. Electric mirror fitment
  101. engine cutting out
  102. Swapping my ecu
  103. 2wd cosworth control arms
  104. 4x4 rear diff whine
  105. Where do I go for a map
  106. Show me your sierra's lowered 40mm on 15's
  107. A Pillar Pod!
  108. 4wd thermostat on 2wd head
  109. Cosworth big wing sump
  110. Is this possible on an RS there it looks awesome ...
  111. unable to flow water through turbo
  112. Sierra spoilers question
  113. Where can I get power steering pipe
  114. F611tab
  115. Are both banjo bolts standard thread
  116. Cosworth recaro rear seat into hatchback
  117. Is a close ratio box the way to go?
  118. 4x4 T3 turbo removal
  119. Pic request-rs500 race car boost gauge.
  120. how long to replace headgasket?
  121. whats the best dump valve for a sapphire 4x4 cos
  122. saggy saff
  123. help needed please think i have a boost prob maybe
  124. Sapph OHC Clattering
  125. What is best to underseal my car??????
  126. 2wd cossie
  127. Aftermarket MAP Sensor?
  128. Fuel gauge stopped working
  129. wanted 4x4 cosworth turbo compressor housing (aka cover)
  130. No dash readings when cold..... Help
  131. fuel line size
  132. front mouth airtec intercooler 100mm
  133. strange ecu problem
  134. Cosworth Ryan engine loom help/info
  135. Can anyone help pls?
  136. 3dr arches
  137. Pectel baby board
  138. cosworth rear track arms??
  139. sapphire head lining sagging
  140. uprated lights for the 3door ?
  141. 3 door cosworth clock
  142. No Fuel Pump power
  143. How many sapphire cosworths were made in black
  144. Cosworth question
  145. Head Thickness
  146. how rare is a 2.4 sierra quick rack?
  147. MINT saph leather interior
  148. fuel line banjo size
  149. Missing under high boost
  150. cosworth fuel pump
  151. no fuel problem
  152. building engine ball bearing turbo into 2wd saph
  153. Does anybody know where I can get a Sierra Sapphire bonnet rubber/seal?
  154. Injector manifold seals
  155. Saff 4x4 starter , mondeo
  156. 3 door cosworth wide wheels
  157. missing in action sapphire cosworths
  158. ARB nut size?
  159. Is the master cylinder (brakes) on 2wd the same as 4wd?
  160. Blue Sensor ECT
  161. Adjustable Valve
  162. Handbrake warning light
  163. Compression strut brackets need to make some!
  164. Secs wiring
  165. Strange running fault!!
  166. New here looking for advise
  167. Help 4x4 saph gearbox
  168. Smoking Cossie. Why?
  169. help on what spec this engine is, any help would be grand!!
  170. Sapphire cosworth boot spoiler caps
  171. problem fitting rs500 ic into saph
  172. 2.0 pinto 4x4 Sapphire
  173. Engine bay decals
  174. cosworth throttle body small screw ??
  175. cosworth tca rose joints and spacers were to get replacements
  176. YB Cooling
  177. Phase sensor issue
  178. Ford Saphire 2.0 GLI
  179. Solid pas rack bushes
  180. Bailey Oil Seperator
  181. Anyone know sierra cosworth G785aoo white?
  182. cosworth cilender head prices.. what they go for?
  183. Fuel pump cut off question
  184. graphic Information Module
  185. Engine loom 4wd to 2wd
  186. Saph Splitter & Mud Flaps ! - anyone got any pics ?
  187. Cossie won't start
  188. P100/Sierra CVH engine mount and oil pan
  189. Airtec RS500 70mm Intercooler
  190. Uprated fan wiring help
  191. Standard 3dr stereo plugs/Loom.
  192. mk1 Sierra check strap
  193. Sumps
  194. 3dr rollcage and sunroof???
  195. OMP Saff rear strut brace question
  196. IACV
  197. Help no power to coil
  198. 3dr roof lining
  199. is this an rs500 block?
  200. help 3 door cosworth with no spark,,, now running again :) :) :)
  201. Sierra XR4x4 Shell - Info Required
  202. Home help in Dundee area.
  203. Moonstone 3 door wheels
  204. Ford sierra sapphire cosworth fog lamps
  205. RS500 Suspension Setup.
  206. rs500 lower spoiler
  207. Rev Counter Shut-off
  208. lamber boss
  209. Cosworth fibreglass dash...?
  210. How to fit Dump Valve to 4x4 Cosworth?
  211. 4x4 Cosworth original heat shield refurb?
  212. Boot struts gone bad!?
  213. Brake bias pedal box on track car yes or no?????
  214. Pinto - Cosworth conversion
  215. Sierra 3dr/RS500 Cosworth Door Cards.
  216. escort cossie front anti roli bar on 2wd sierra cossie
  217. Cosworth 4x4
  218. RS2400 Sapphires - 2wd and 4x4
  219. Please please help brake problem
  220. Water leak...help
  221. honda s2000 speedometer,on 3dr
  222. Turbo
  223. Cosworth knock sensor help??
  224. heated recaros?
  225. When Zebra Stripes stalked the Earth......
  226. Standard Cossie wheel nuts?
  227. Bumper Tryouts
  228. Sierra Group A side exhaust
  229. anyone know where e640jlt is? my first cosworth
  230. High fuel pressure Sapphire Cossie 4x4
  231. Adjustable TCA's ?????
  232. High idle on saph, dodgy wiring to phase sensor, or likely cause?
  233. Co help
  234. under wing oil catch tank ?
  235. Anyone using gaz coilys?
  236. I've fooked up on the wings
  237. Wiring in a digi dash in a 3dr
  238. Converting 2wd to run P8ecu
  239. 3 door owners
  240. 3dr carbon bonnet £?
  241. Marlboro-Carlos Sainz-Tour de Corse 1987
  242. rear window removal - HELP
  243. 3 doors
  244. Tracking Down an Old Sapph
  245. Very short video of my 4x4 saph with new straight cut box
  246. Stack gauges
  247. Big Brakes & CXNs
  248. Brake Res Bottle Full
  249. is it possible to check a t5 out of the car
  250. Headlight Relay?
