- sierra 3 door replica, 4 pots do not fit !?
- hot and cold.miss fire
- Alternator belts too short all of a sudden DOH!
- Rear prop UJ part number
- A few pics of saph today
- Winter Speedline Wheels on the 3 Door
- Possibly last day out in saph this year
- damaged sapphire on ebay?
- Looking for 3dr cossie D370HMS
- supra diff conv .Whats involved
- cosworth fuel pumps
- Cosworth engine
- Front bumper mounting?
- RS500 fog lights replacements..
- White 3 door Pics please
- saphire cosworth 4x4 mis fire when cold fine when hot
- what does this pulley do ?
- away for winter so a few improvements to be done 500+ bhp here we come
- granada parts on sierra
- 2wd Sapphire Cosworth info
- Cosworth head hight
- Compression strut kit
- Brake pedal travel
- Sunroof what's best to cover it????
- PAS Tanks
- Replacing saff cossie rear trailing arms
- where to get new brake reservoir for a saff
- Moonstone Cosworth out for a drive
- Angel eye headlights
- PF09
- Cosworth anti roll bar mount bolts, what size?
- who makes the best t34.48
- RS500 heat shield
- Loom wiring diagram needed
- Aquired wheels
- 3 door wastegate
- 12mm plenum spacer are they any good???
- ABS wheel sensors
- are xr4x4 front calipers the same as rs turbo ones?
- pectel baby boards versions vs. lambda
- What does it mean
- polyflex rear beam bush fitting
- MSD wasted spark,HELP!!!!!
- Ford sapphire cosworth headlights
- Removing the flame trap and keeping the kidney box on a cossie (Revised)
- slight hesitation/judder on sapph 4x4
- Sapphire wiring
- Sierra Cosworth Car Battery....
- Is possibly to get more power at low rpm with std cams and verniers?
- Engine loom grommet
- 1'st start-up (hopefully)
- Best Head Gasket
- Wanted! F.bumper & bonnet for 3 door cosworth
- Injectors…
- any one no this cosworth g481 ouf
- ABS Pump Motor feed
- 3dr fuel pump relay earth question
- MSD wasted spark system installation
- Clutch Issues
- Old style brake servo on a Cosworth
- Cossie owners in Scandinavia
- 4x4 sump
- Sapphire out for a few pics
- Sapphire Cosworth color mat black
- Sierra Cosworth 2jz 2jzgte 650hp
- 4wd to 2wd
- Rs500 boost pipes????,
- ECU
- tie rod ends
- cosworth mls head gasket would you re-use??
- Oil Seperator
- Rs500 block and head
- Sierra Saph seat rails,
- wiper stalk
- spec advice needed please
- Swapping front seats?
- Vin plates
- BBS 3 Piece Split Rims.
- Rs500/3dr cosworth gearknob
- Header Tank
- underbonnet wiring on cossies a mess any ideas
- Rs500 / rouse splitters who does the best reps
- sapphire question light switch
- Saff side skirt clips
- 200 block cosworth ?
- Sapp Cosworth runs strange
- Changed phase sensor and hard to start
- Last drive of the year, sorn from tomorrow
- '-31 ACT' Spring Pressure.
- Any idea what turbo this is or how to identify
- L8 ECU running High Impedance injectors
- cosworth diff mount 2wd whats the best?
- The 30 amp fuse in pass footwell keeps blowing
- Checking a diff-choice of two...
- Cossie Front Crossmember
- Sapphire Cosworth Car cover
- 3dr cossie shell no sunroof??
- Ford sierra cosworth 2 front wings
- Cosworth Coilover springs
- Magenta g409 peg anyone
- how much play do you have in your diff on axle stands?
- When was the 200 block introduced ?
- Gaz Gold on a 3dr.
- grahame goode beam bushes...anybody used um?
- cosworth 3dr pic request
- 3.9 diff - anyone tried one?
- 2.0 OHC EFI low comp
- L8 048/01 ECU maps check
- Ford electrical conectors
- Ford sierra sapphire cosworth front wing mouldings
- Cosworth Dizzy.
- Sierra Sapphire Spoiler, colour of your choice and caps?
- Took the 3 Door out at the weekend
- Saff arch liners with rolled arches?
- How much?!?! T5 Speedo Drive
- breather
- ABS romoval/disconnecting/bypassing loom???
- cosworth fuel lines diameter?
- HELP!!!! manual Mk1 Sierra wing mirrors
- Bent back end. Advice please.
- 2wd No spark,No live to Ecu
- boost/vacuum tubing size?
- 3dr help needed???
- Total loss of power...
- info required
- 2wd cosworth engine loom
- cam pulley help
- Ford radio
- Santa claus was early this year
- pinto tubo parts suggestions
- l6 chip
- Hart Plenum in LHD car
- Jumping acceleration while driving
- rs500 rear spoiler
- water gurgling noise behind dash
- Anyone know the part number for these?
- Sapphire dash light bulbs
- Front bumper adjustment
- YB Inlet Manifold
- 909 rear differential
- cosworth part?
- how many left?
- GT30 Turbo oil feed thread size?
- ECU map for L8 048/01 green top
- Rear arch liners
- Replacement engine, fan and fuel pump looms, where from???
- Saff rear beam mounts
- Identifying 2wd loom parts, help needed.
- Aircon on sapphire
- which diff oil
- What exhaust manifolds is everyone running on the 4x4 cosworths
- Cosworth problem
- yb engine into 2.0 litre twincam shell
- 3dr carbon parts
- Time for some more grip
- Sills and Repair Arches
- konis or coilovers
- 4x4 sapph shaking :-(
- Central locking 3 door
- To cam or not?
- Fan
- sierra 3 door cosworth rally info wanted
- Best place to buy a 2wd Cosworth clutch....
- Got the car out today,luvly!
- tyre pressure toyo r888 ?
- 1.6 cvh gearbox!
- Saff roof. Rusted
- Been out in the 3 Door today, Awesome!
- Cosworth not running right
- Interior clock
- Cosworth Tyre Pressures and Handling?
- Turbo heat sheild (3 door)
- How to tell genuine front wings??
- What are these loom plugs?
- Some Discount for you all!
- should i get rid
- Saff cossie rear arches with pics
- Did any of the early YB's run on leaded?
- Cosworth wiring experts needed!
- 803 equivalent injectors
- scorpio cosworth 24V rear calipers?
- will these wheels fit ?
- New law on modifying
- Saff under bonnet stickers where from?
- T34 Turbo
- What is the going rate to rebuild a Cosworth T5 Gearbox?
- New 4WD Wheels flanges ?
- skyline 6 speed box adapters? do they exist?
- Nothing from starter motor.
- Rs500 competition manual
- Had the 3 Door mapped Friday
- Cosworth rattles, bumpy
- phase sensor
- cvh gearbox same as 1.8td??
- Still idling too high
- more power out of 2.0 dohc
- Saff horn relay
- Possibly that last registered Sapphire Cosworth
- cossie rear caliper problem
- Land rover brake master cylinder
- Lenso Bsx Wheels Users!!
- saff cossie rear suspension arm bushes
- Starter motor trigger
- sierra sapphire rear electric windows
- anyone help
- Where to buy sapphire 4x4 bonnet vents?
- cosworth plumbing and header tank
- air temp gauge wiring??
- MSD L8 evo chip.
- Where to buy a new loom?
- short shifter for type 9/ xr4i-xr4x4
- 2 brake/fuel pipe clips needed, with pics**
- Talk to me about YB breathing please
- Where these parts come from ?
- Picture request ... 3dr tyre pressure chart
- 3 door hubs
- Newbie
- Hard to find accurate figures how many cosworths are left?
- cossie running issues
- Sapphire cossie 4x4 help
- Help needed for my Sierra Saph 'Look-alike'.
- Grey injectors
- Sierra Cossie with dash removed?
- strut brace for boa
- sierra sagging roof lining
- Cam colour cover
- rwd focus wanted
- is it a 3 bar?
- intermittent smoking problem
- Ride height different
- What turbo is this?
- MAP Sensor
- 3dr front badge
- hard brake pedal
- YB valve guide removal
- Cosworth fuel pump wiring ?????
- Gearbox Shifter Bush
- Where do my badges go!!
- Propshaft play-need new rubber or bearing?
- Removal of 2wd engine loom
- brakes that fits std. escort cosworth wheels
- cosworth overboost
- cosworth .25 pistons
- Intermitent non start while hot
- Saph headlining removal
- ABS Help please 2wd Cosworth in P100
- Ignition Relay
- Oil coolers, need advice..
- Need help with camshafts
