cosworth plumbing and header tank
just need to double check with anyone in the know , as i dont use the original cossie rad in my setup , does the outlet from the header tank just "t" in to the bottom hose inbetween water pump and bottom rad hose ? or somewhere else ?
using the 2wd thermostat housing if that makes any differance and custom alloy header tank with the same in/outlets as the original
cheers
cheers
AndrewStrang
01-09-2015 11:16 AM
155lee
14-08-2015 11:21 AM
