phase sensor
Old 31-08-2012, 11:08 PM
davy 6457
davy 6457's Avatar
Default phase sensor
hi all, small problem but know the problem, was working at a mates saph cossie the other evening fitting new plugs,cap,arm and phase sensor to try and sort out a missfire. anyway all new bits fitted and went to start her up and nothing, just turned over and wouldnt fire. so i went back along the bits fitted just to make sure everything was ok and checking gaps and all was good, so checked for spark at cyl 1 and sure enough there was spark.anyway we spent a while checking other bits out and eventually we decided to try some old bits on again and hey presto once the old phase sensor was fitted she fired up no prob!!! has anyone else came across this problem before or is it just a case of a duff phase sensor?
magnet was fitted to new one as well
Old 01-09-2012, 10:10 AM
Paul_RS
Paul_RS's Avatar
Could be a wiring loom problem too.
Old 01-09-2012, 10:58 AM
Turbosystems
Super Moderator
Turbosystems's Avatar
did you connect the new one the correct way round
and did you set the gap correctly
Old 02-09-2012, 08:30 PM
davy 6457
davy 6457's Avatar
yeah everything was set up right, as said once the old one was in again the car ran no bother!!! i think the sensor is just fu*ked
Old 02-09-2012, 09:14 PM
daz1968
daz1968's Avatar
I had a similar issue with a new phase sensor so kept my old one in and I was 100% confident it was connected and gapped correctly. So they may be faulty at times. Was it a genuine magneti one,
Old 03-09-2012, 09:03 AM
davy 6457
davy 6457's Avatar
yeah got it at ford fair couple of yrs ago, just kept it for a spare but i think its ready for the bin now!!!
mark94
Ford Mondeo Including ST
10-10-2023 06:52 PM
01-11-2015 06:53 PM
Mark RS
12-10-2015 06:01 AM
fordrallycar
30-09-2015 07:57 PM
stevecfrst1
30-09-2015 05:18 AM
Quick Reply: phase sensor
